Username: Sunil59 Post Number: 23 Registered: May-06
Friday, February 08, 2008 - 01:32 GMT pls help me in viewsat extreme with setting up key in nagra for dishnetwork how many places have to change keys and how can some body help thanks
Username: Lol Post Number: 315 Registered: Sep-06
Friday, February 08, 2008 - 01:40 GMT install latest file turn to channel 200 and sit till it rolls
Username: Sunil59 Post Number: 24 Registered: May-06
Friday, February 08, 2008 - 01:45 GMT yes i did instal the new bin but at the time of entering the key i some how deleted the top line where it says 00 after 00 what are the numbers
Username: Sunil59 Post Number: 25 Registered: May-06
Friday, February 08, 2008 - 01:50 GMT 00-missing 08-95 AF 68 2B 92 2E D4 77 09-39 3B 59 17 F5 34 46 77 88-6A 8D 64 D3 77 B5 B4 B4 89-B8 81 93 19 84 7D 80 F8 what comes on the top of line
Username: Sunil59 Post Number: 26 Registered: May-06
Friday, February 08, 2008 - 01:58 GMT pls somebody help
Username: Doreenakadj Ontario
Post Number: 1157 Registered: Dec-06
Friday, February 08, 2008 - 02:11 GMT How To Enter Keys Manually In Your Xtream. 1. Menu 2.Installation 3.Enter Pin 0000 4.Code 5.Nagra 6.Left until you see what ever Satellite you want. Put 00 keys on line 08 & 09 don't change the 08 or 09 number Put 01 keys on line 88 & 89 don't change the 88 or 89 number EXIT once then OK to save, the light color is the one you pick to save then EXIT out.
Username: Scott21 Post Number: 19 Registered: Sep-07
Friday, February 08, 2008 - 02:11 GMT do a factory file and then put in new bin. it should help. if not it will not hurt anything.
Username: Sunil59 Post Number: 27 Registered: May-06
Friday, February 08, 2008 - 02:27 GMT can you pls chq your reciver and give me numbers
Username: Madflea168 Post Number: 212 Registered: Jan-08
Friday, February 08, 2008 - 08:30 GMT B4 ED 24 E3 BC C1 82 69 E1 B0 09 C4 C1 D0 C8 A1
Username: Grease Canada,
Ont.
Post Number: 1 Registered: Feb-08
Friday, February 08, 2008 - 15:34 GMT suni here are top line numbers A3 63 F4 11 BC A3 B1 AC
Ont.
Post Number: 2 Registered: Feb-08
Friday, February 08, 2008 - 15:38 GMT SUI SORRY FORGOT LAST NUMBERS E1 B0 09 C3 C1 D0 C8 A1 try these whith others.
Username: Metallica Post Number: 60 Registered: Jan-08
Friday, February 08, 2008 - 15:38 GMT Mad Flea is the right one for the 00 keys missing. this is the one for the 00 keys.. B4 ED 24 E3 BC C1 82 69 E1 B0 09 C4 C1 D0 C8 A1
Username: Sunil59 Post Number: 28 Registered: May-06
Friday, February 08, 2008 - 15:50 GMT Thanks will try
