continues to autoroll for viewsat extreme with bin DBPSW-080204X anyone else has this problem?? I tried loading the bin a few times and it still wont work I did a factory rest and I loaded the factory bin nothing seems to be helping and Ideas?
nancy..after you finish loading the bin..disconnect the cable turn it off from the back for a minute then turn it back on and find a local channel stay there and let it roll... my VS extreme don't even need to roll..finish loading the bin turn it on there are picture.
If this is a new STB you should get at least four files before you start. LOADER2.ZIP An up to date Bin, DBPSW_060814ES_XTREAM.RAR A Satellite List, there are two files here. You need to pick the file that has the Satellites you want. Walace to unzip the files, you can get it here h**p://www.emantechnology.com/lookangle.asp J-TRACK SHOWING POSITION OF SATELLITES h**p://science.nasa.gov/RealTime/JTr.../JTrack3D.html FIND A SKEW h**p://www3.telus.net/rampage/skew.htm
CLEAN AND PUT LUBRICANT ON YOUR REMOTE. Use ProGold G100P from Radio Shack part number 64-4337
