This for SADA need help plz
Username: Mriaz
Post Number: 35
I am trying to san but no signal at all. Downloaded new BIN 248T still 0 Channels found. When I press (SIG) the SKEW is UNLOCK. It should be LOCK, but I don't know how to LOCK to get signal. Please i will appriciate it if some one help me.
Thank you!!
Username: Saqeeb9000
Post Number: 2109
put your setting here..
go to menu installation ,antenna settin ... put all your setting here.
Username: Mriaz
Post Number: 36
First off thank you for replaying.
When i go in installation i set every thing for 61.5. My antina qualitilaval is ok but i don't have Signal strenth at all. so when i scan all at the end it says 0 transponder found. There is no Signal strenth at al. How do get get back SIG back please
Post Number: 2112
see thats why i told u put your setting here..
you have to make ur
sat 61.5
lo freq.. leave it what ever it says
22 khz off
disq eqc this is main thing ( which port ur 61.5 is .. 1,2 3, or 4 depends on how many dishes u have .. when u change it it will show you green signal..
multi dish switch ... disable.
morsetting ..off
lmb power .. on
Post Number: 2115
are u stil there riaz.. did u tried the setting i gave you..
Username: Mriaz
Post Number: 37
Thos is Eagle Star Converted Flu
For 61.5
LNB = Standard
LNB Local-fre = 11250
22 Kz = OFF
DisEqc = #1
Legacy SW = None
Skew = -45
TP ( Try to change one by one, No diffrenece
Positoner Setting = Disable
Satalite Scan = ALL
Note: Level = 90%
Qualty = 0%
Now i guess it will easy for you to understand the problem for me
Post Number: 2116
don't change tp... first of all
try to change diseqc 1 ( how may dishes you have)..
make sure every thing is conneccted in back ..
cable from sat goest to lnb in..etc..
and try that..
Post Number: 2117
on my 148 dish local freq 11250
Username: Mriaz
Post Number: 38
I have another FLU , that work fine when with the same seting. So my connection is fine and all the seting. This is something wrong with (SIG), It should say lock but is says unlock.
Username: Way2smart
Www.desifta.tk
Post Number: 1140
hey sada we need this to catch 118.7.....http://cgi.ebay.ca/DUAL-CIRCULAR-LNB-LNBF-CB2008A-FTA-118-7-DISH-119-118-8_W0QQi temZ150213166732QQihZ005QQcategoryZ149971QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
go and check it out... sorry to hijack..
Username: Mriaz
Post Number: 39
Can you please go to your thread
Post Number: 2118
ok smart thanks...
riaz.. where is sig.. setting..
Username: Mriaz
Post Number: 40
if you have solution please post it, other wise good night. I tird wanna sleep now. It is 12 midnight now
Username: Mriaz
Post Number: 42
when you press SIG button on the remote, it will take you to level and signal window on the TV. There you can see it is says LOCK and you se both level and signal bar High.
Post Number: 2120
every thing looks good here..
may be ur dish is moved or some thing..
thats all i can tell you.. more help will come from nalin ... he is master in converted flu's ...
i don't have this rec..
try to do a factory reset , and new bin and scan channel again.. may be u need a channel list using channel master...
sorry thats all i know..
tried to help what i can ....
come back tomorrow..
and ask for nalin...
Username: Mriaz
Post Number: 43
ok thanks
Username: Wizzard2004
Post Number: 11
is tehre a fix for pansat 2500 to 2700 for DN?
Username: Way2smart
Www.desifta.tk
Post Number: 1143
yes W crazyfta....
