Bronze Member Username: DevenwMISIS Post Number: 50 Registered: May-06 | I`m keep getting message on my Pansat 2500 to 2700 converted. After i download new bin 245 x-87bl_080126_b75_245_api |
Gold Member Username: Cartier1Post Number: 1717 Registered: Feb-07 | reload it again. |
Gold Member Username: NydasPost Number: 7731 Registered: Jun-06 | You have made a serious mistake. I have given detailed instructions in the other thread. |
Bronze Member Username: CubicheCUBA, CUBA Post Number: 46 Registered: Jan-08 | you loaded an original pansat 2700 bin.thats a nono |
New member Username: HoudiniPost Number: 3 Registered: Jan-08 | Hello guys: My flu remote keeps shutting system off keeping me from setting the system, any idea please thanks |
Gold Member Username: NydasPost Number: 7748 Registered: Jun-06 | 1. Save current user settings and antenna setup 2. load BIN - Jvvh_FortecRemote_245.bin. CS_245T_Lightning_100t_Series_serial.bin also works. 3. Do defualt system 4. Do User setup - date time. Turn closed captions off. 5. Do Antenna setup with one sat only. 6. Do blind scan. 7. See TV working. 8. Do other antenna setups and scans. 9. Turn off autoroll. 10. Set up favourites. 11. Use favourites and EPG button to change channels. |
Gold Member Username: NydasPost Number: 7749 Registered: Jun-06 | If you can't understand above The full kit is in full_kit14C.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file. http://public.box.net/2500_full_kit |
New member Username: Rockman169Canada Post Number: 9 Registered: Nov-06 | im trying to save my channels but dont no what meaned by upgrading from from b2 to b75 please help thanks |
Silver Member Username: Albino_midgetPost Number: 669 Registered: Jul-06 | Rockman169, the pansat 2700 had a boot file upgrade from b-62 to b-75 the b-75 needs to be loaded before any new bins check your 2700 by pressing menu , system info will be on that page . if you have boot ver. b-75, use loader 27.02 to load the latest bin. if boot ver. b-62 , b-75 upgrade needs to be done . |
Gold Member Username: AsharfiPost Number: 1775 Registered: Aug-06 | Sharuk, You are using the WRONG bin file and you'll end up killing your FTA receiver. Those converted receivers need either Chancysand bins or JVVH bins. |
Bronze Member Username: McrabbycabbyWpg, Man Canada Post Number: 43 Registered: Jun-06 | what bin do we use to convert a panset 2500 to 2700 its a PANSET not a pansat thank you |
Bronze Member Username: McrabbycabbyWpg, Man Canada Post Number: 44 Registered: Jun-06 | what bin do we use to convert a panset 2500 to 2700 its a PANSET not a pansat thank you |
Gold Member Username: NydasPost Number: 7802 Registered: Jun-06 | Terry: Just download the kit. The full kit is in full_kit14C.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file. http://public.box.net/2500_full_kit |
New member Username: JatheonePost Number: 1 Registered: Feb-08 | ya i made same mistake as the guy that started this tread just started loading my own converted fortec my friend was getting tired of replacing the bin everyday and I loaded the wrong bin any help or is it a paper weight |
Gold Member Username: NydasPost Number: 7820 Registered: Jun-06 | Be precise. What is the receiver and what did you try to load? If the original receiver is a 2500 or FLU, use the instructions in the "revert to 2500" subdirectory. |
Bronze Member Username: McrabbycabbyWpg, Man Canada Post Number: 45 Registered: Jun-06 | thanks nalin. |
New member Username: JatheonePost Number: 2 Registered: Feb-08 | converted flu and i tried to load pansat bin 245 not the cs245 |
Bronze Member Username: DevenwMISIS Post Number: 52 Registered: May-06 | Nalin it`s Me again? What should i do first, i`m bit confused which bin should i use |
New member Username: JatheonePost Number: 3 Registered: Feb-08 | hey sharuk did you load wrong bin and now no power or something else |
Bronze Member Username: DevenwMISIS Post Number: 53 Registered: May-06 | No jay I`m keep getting message on my Pansat 2500 to 2700 converted. After i download new bin 245 x-87bl_080126_b75_245_api as you know, i have dowlolad the kit on my Pc and i doon`t know which file to load on my receiver first. |
Bronze Member Username: DevenwMISIS Post Number: 54 Registered: May-06 | jay or nalin please help me |
New member Username: JatheonePost Number: 4 Registered: Feb-08 | sorry sharuk but I have the same problem if you find out how to fix then let me know i will do the same |
Gold Member Username: KirankumarKenya Post Number: 1278 Registered: Oct-07 | guys, both of you go to crazyfta and get live help |
Bronze Member Username: DevenwMISIS Post Number: 55 Registered: May-06 | Nalin, Please help, i don`t wanted to kill my receiver by loading wrong file again. Which file should i download first? |
Bronze Member Username: MetallicaPost Number: 15 Registered: Jan-08 | Sharuk...did you finish converted your 2500 to 2700? when you turn on your box did you see B75 come up? if not you have to follow Nalin instruction to converted it to 2700 first.. after you have finish all of that.. this is the files you need. Jvvh PansatRemote 246 (BEV FIX!!) 2500 to 2700 with the words JVVH in the bin files...those are the only files use for the 2500 converted to 2700.. |
Bronze Member Username: DevenwMISIS Post Number: 56 Registered: May-06 | Hello Metalika Yes i`m getting B75 error on my reeiver, i have converted from 2500 to 2700 way back however last week i downloaded new bin 245 x-87bl_080126_b75_245_api and according to Nalin i have dowloaded wrong bin. Please help me |
Bronze Member Username: MetallicaPost Number: 17 Registered: Jan-08 | this is the right file.. Jvvh PansatRemote 246 (BEV FIX!!) 2500 to 2700 with the words JVVH in the bin files...those are the only files use for the 2500 converted to 2700.. |
Bronze Member Username: DevenwMISIS Post Number: 57 Registered: May-06 | so what shoud i do now? |
Bronze Member Username: Tibie11Post Number: 27 Registered: Sep-07 | bev work with bin 246??? |
Gold Member Username: NydasPost Number: 7825 Registered: Jun-06 | when you started you said, you have a converted receiver. You loaded or tried to load a genuine Pansat 2700 BIN - That is a NO-NO. Now things are so confusing, that if you have light and you have B-75 flashing accross, try an dload CS_245T_lightning file of jvvh_245 or jvvh_246 file. Get the files from http://public.box.net/2500_full_kit If unsuccessful, then look at the "Revert to 2500" directory and patiently follow the instructions to revert to 2500. Then follow the instructions to convert to 2700 and load the latest BIN. The instructions are pretty clear and exhaustive. |
Bronze Member Username: King_of_satsPost Number: 13 Registered: Jan-08 | http://public.box.net/2500_full_kit Unconfirmed download site. I for one think it's a Dish Network sting operation. The woman Nalin can't be trusted. After the fiasco where she misinformed many fta users and killed 100's of Pansat boxes. I and many others users on this site believe she is working for either nagravison or echo. |
Gold Member Username: NydasPost Number: 7830 Registered: Jun-06 | Do not listen to King_of_SKUNKS. The site http://public.box.net/2500_full_kit for downloads relating only to 2500-2700 conversions is fine and authentic. |
Bronze Member Username: King_of_satsPost Number: 14 Registered: Jan-08 | skunk this B!tch 8=======D Your a mole for either echo or nagarvison. I've read the messages where your were working on some new ECM'S what sort of respectable pirate post's a message discussing ways to to stop it. You are one sick and twisted female. That has no place in the game of FTA. |
Gold Member Username: NydasPost Number: 7833 Registered: Jun-06 | King_of_SKUNKS: DON'T WORRY. NOBODY ELSE WANTS YOUR WELL-DESERVED TITLE. |
Bronze Member Username: McrabbycabbyWpg, Man Canada Post Number: 46 Registered: Jun-06 | i agree with nalin he's kept my pansat up and running thanks nalin. |
