Satellite..............EchoStar 8,10 (110°W) LNB Power .............ON LNB Type...............OSC-DP (If you have DP LNB, otherwise set it to STANDARD) LNB Freq...............11250 22KHz..................OFF TP Freq................12224 DiESqC 1.0.............Port 2 Motor..................OFF Legacy SW..............None
Satellite..............Echostar 7 (119°W) LNB power..............ON LNB Type...............OSC-DP (If you have DP LNB, otherwise set it to STANDARD) LNB Freq...............11250 22KHz..................OFF TP Freq................12239 DiESqC 1.0.............Port 1 Motor..................OFF Legacy SW..............None __________________ I am guessing at what dish you have
