New member Username: UsaPost Number: 1 Registered: Jan-08 | can someone tell me what DN and Bev mean?? Thenk you.. |
New member Username: UsaPost Number: 2 Registered: Jan-08 | and why do i need them? |
Gold Member Username: Saqeeb9000Post Number: 1870 Registered: Oct-07 | bencepa dN means dishnetwork channel.. dishnework channesl they are located on 148,110,119 degres.. means dish pointing towards on those degrees( on roof) etc... when u call dn means they install the dish pointing towards anyone of those directions.. or you can ask the installer to install a dish for you... u can buy a reciver fta reciver like viewsat,sonicsat and see those channels without paying to dishnetwork.. remember its not a legal subcription.. similarly bev means bell canadian channels and they are located at 82,91 degrees. hope it helps.. |
New member Username: UsaPost Number: 3 Registered: Jan-08 | can you help me , i am using the COM 1 port and i have viewsat platinum 2000, i pluged the modem cable at my pc and the reciver , the revier is closed and i open loader2 open the file and click the PC-STB and open the viewsat but it stays like that all the time it dosend download what is the problem i did everythig right why is this happening ??? |
Gold Member Username: Saqeeb9000Post Number: 1871 Registered: Oct-07 | you need to turn on the reciever after u plug in cable and open the file.. when you click on open the file and connect then turn on reciver from back (so ist it should be turned off).. then it will say start updating...etc... |
Gold Member Username: Saqeeb9000Post Number: 1872 Registered: Oct-07 | here is the setup video..it will show you step by step instruction using loader2 Viewsat Setup Video Tutorial.zip |
New member Username: UsaPost Number: 4 Registered: Jan-08 | can someone give me the right loder2 please??? |
New member Username: UsaPost Number: 5 Registered: Jan-08 | when i donwload the loader2 it only haved the fallowing files:: Loader2, Loader2 User Guide , readfirst and dhe Zmodem32.dll i saw the video that you gave me and the guy in the video had the : 2-21-06 opkey.hex Viewsat La 110 119.cha , VS2000_NEWOSD_V1053.PGM, Viwsat La 110 119.sat vs2000_newosd_extrebe_v1054 Zmodem32.dll i need them too i only have the ------------ Loader2, Loader2 User Guide , readfirst and dhe Zmodem32.dll |
Gold Member Username: Saqeeb9000Post Number: 1875 Registered: Oct-07 | https://www.ecoustics.com/electronics/forum/home-video/266022.html here you go link for viewsat loader.. look at the link for video it will show you step by step direction.. and for new bins etc.. go to www.d*esifta.co.nr |
New member Username: UsaPost Number: 6 Registered: Jan-08 | when i donwload the loader2 it only haved the fallowing files:: Loader2, Loader2 User Guide , readfirst and dhe Zmodem32.dll i saw the video that you gave me and the guy in the video had the : 2-21-06 opkey.hex Viewsat La 110 119.cha , VS2000_NEWOSD_V1053.PGM, Viwsat La 110 119.sat vs2000_newosd_extrebe_v1054 Zmodem32.dll i need them too i only have the ------------ Loader2, Loader2 User Guide , readfirst and dhe Zmodem32.dll |
Gold Member Username: Saqeeb9000Post Number: 1876 Registered: Oct-07 | no you just need one file . just click on open and file that you downloaded and saved on desktop etc.. just open file on loader.. it will put it on right place.. and then turn on ur reciever from back.. you shuld see it updating.. let it downlaod completyly wait 2 -5 minutes and then unplug it.. |
New member Username: UsaPost Number: 7 Registered: Jan-08 | i tryd it many times and it wont work , why the guy in the videos has those files ??? |
Gold Member Username: Saqeeb9000Post Number: 1877 Registered: Oct-07 | u just need loader 2 and prgm file |
New member Username: UsaPost Number: 9 Registered: Jan-08 | ok , give me a right bin file so i will se if it works, cause i styed many times and it wont work , please send me a bin.. files |
Silver Member Username: IduknowPost Number: 108 Registered: Jan-06 | viist http://en.wikipedia.org/wiki/DN, for all definitions. |
Gold Member Username: Saqeeb9000Post Number: 1878 Registered: Oct-07 | what is not working .. is it file ? tell me the site where you download it from.. did u extract the file ..save it on somewhere.. its easier to save on documents.. then open file and then click on connect and turn on from back... |
New member Username: UsaPost Number: 10 Registered: Jan-08 | i got it from here, do u have those files like the guy in the video? |
Bronze Member Username: UsaPost Number: 11 Registered: Jan-08 | i know i extraced i deed it i open the file and .... then e press PC-STAB on the loader2 the only MAIN SOFTWARE box is checked , i think its like that cause i saw the video... |
Gold Member Username: Saqeeb9000Post Number: 1879 Registered: Oct-07 | [link removed] here is the file for viewsat plat.. |
Gold Member Username: Saqeeb9000Post Number: 1880 Registered: Oct-07 | so is it downloading or not.. are you using right cable..... is it the first time are you downloading.. did that cable come with ur reciever.. |
Bronze Member Username: UsaPost Number: 12 Registered: Jan-08 | the cable is ::: Shielded RS-232C Cable this is the name. i buyed the cable |
Bronze Member Username: UsaPost Number: 14 Registered: Jan-08 | the cable is ::: Shielded RS-232C Cable this is the name. i buyed the cable is this the right one ????????? |
Bronze Member Username: UsaPost Number: 15 Registered: Jan-08 | i do everything right but it wont start downloading in the STB |
Gold Member Username: Saqeeb9000Post Number: 1881 Registered: Oct-07 | |
Gold Member Username: Saqeeb9000Post Number: 1882 Registered: Oct-07 | i think problem with your cable ... what kind of comp do u have.. |
Bronze Member Username: UsaPost Number: 16 Registered: Jan-08 | the cable is femate to female is it good ? |
Gold Member Username: Saqeeb9000Post Number: 1883 Registered: Oct-07 | it should be like that..but to make sure ...go to sat shop and ask for viewsat loader cable.. they will give u the right cable.. i remember when i bought my first cable i bought few of them before buying right one... |
Gold Member Username: KirankumarKenya Post Number: 1192 Registered: Oct-07 | usa go to radio shack and buy male to female null modem adaptor for $9.oo and hook it up to the end of your 232 cable and it should work |
Gold Member Username: Cartier1Post Number: 1719 Registered: Feb-07 | NO DONT BUY AN ADAPTER. USA GO READ AND READ AND READ THIS WAY IT WILL BE EASY FOR YOU . YOU CAN SPEND A HALF CENTRY HERE ASKING QUESTION AND U WILL NEVER MAKE IT RIGHT. HOW SOMEONE CAN EXPECT YOU TO MAKE IT RIGHT IF IN THE 1ST PLACE YOU ASK THE QUESTION :: usa New member Username: Usa Post Number: 2 Registered: Jan-08 Posted on Tuesday, January 29, 2008 - 07:50 pm: -------------------------------------------------------------------------------- and why do i need them? -------------------------------- WHO SAID U NEED THEM . YOU DONT EVEN KNOW WHAT IS GOING ON . SO DO SOME READING IF YOU CAN NOT GO PAY SOMEONE TO DO IT FOR YOU . |
