im tryin to say like when my viewsat has been runnin for a day or so after being reseted well than like when i go to guide and press info than i have to press exit twice to get out of it and like when i press the privous channel button i gotta press it twice and not every window goes down in one press when i turn off and then turn on the receiver again from the back than it all happens in one click.
You should try loading a factory BIN on the receiver, then put the latest bin and rescan the channels. I was having a similar problem with having to press buttons on the remote several times to get it to react. After doing the steps mentioned, my remote works normal.
