Viewset Pro Loader
Username: Frobi
Post Number: 167
Which loader should I use for bin file for Viewset Pro? Same as Viewset Extreme? Thanks
Username: Jurj1
Post Number: 456
Loader2, yes
Username: Nydas
Post Number: 7641
[link removed]
VS-Pro LOADER
HERE IS the working VS-Pro loader....
You need to have your vspro off when installing.
1. open vspro program
2. connect to stb
3. make sure stb is on off position
4. click on download to pc and watch it load to 100%
5. once done completely shutdown from the back, wait a couple of secs. and switch it back on
VSPROLoader_Setup.zip
Username: Madflea168
Post Number: 142
you can use the usb stick.
Username: Frobi
Post Number: 168
Thanks Nalin and Tony Soprano
