Ftahq.com it's enought
Username: Plymouth
Quebec city, Quebec Canada
in my System Setup, what i see where it spposed to be the satellite name [link removed], i never download from this site, and it's impossible to receive Dish 110 and 61.5 autoroll always.
Viewsat Ultra, HH90 fortec 36" QPH-031}
Username: Plymouth
what is the best for reset factory, by null cable or USB
Username: Saqeeb9000
Post Number: 1684
factory reset.. u can do it using remote.. by menu ins, factory reset...
factory reset is different than factory bin installation..
factory bin is that what u can do it with usb or null either ur choice...
if u are having problems just do a factrory reset (bu using remote) and then install new bin...
if it still doesn't solve ur problem intall factory bin and latest bin again..
and don't go to www.ftahaq.com (its hijacked)
try www.desifta.co.nr
Username: Way2smart
Http://desifta.co.nr/
Post Number: 605
yaa u wanna sta away from the ftahaq and try desifta much better and more reliable for files and other needs
Username: Thugged
you guys do know that this is a one time thing right
the reason it says ftahq in your menu is because viewsat wanted to clear up all doubts about its release site, and shut up stupid people
Username: Plymouth
I tested but it does not work
Username: Plymouth
since approximately 2 week I have this problem with Dish
Username: Plymouth
hey inconito Gene who you call stupid, what you have for said stupid
Username: Thugged
i didnt call anyone stupid
Username: Plymouth
OK GENE but they don't solve my probleme
Username: Plymouth
Post Number: 7
i have created a new satellite and blind scan 110W and this is solve.
Username: Nydas
Post Number: 7460
Considering the number of viewsats that have been sold, I see very few complaints about DN or BEV scanning, in this and other forums.
Something must be working right.
Username: Pro5188
Louisa, Ky United States
ha plymouth i to have sean this in my ultra to day in the top right where it show what sat you lock on it show [link removed] and that the first time its bin there can any one tell me why
Username: Razzorwyre
Post Number: 169
I also have the latest bin for Ultra with www.ftahg.com coded into the menu screen. And in fact it DOES work and has no freezes glitches or anything. I have even d/l it from a few different sites and it has the same coded into the menu so relax and watch tv.
Username: Pro5188
ok this a good one i went to a site that says its total f t a , and it telling everone to stay away from this site [link removed] . it say it a bad site . if so then why does this site come up in my ultra reciver . me i think the site totalfta site is bogest a bad site ./ the www.ftahQ site i belive is the real site . so watch out
Username: Grxmites
thats actually the official site for the viewsat recievers... it used to be totalfta then that got hijacked, then it went to thetotalfta and now its ftahq hence why it has that on the menu... if u go to totalfta they ask u to reregister where as if u go to ftahq it already has your old login...
that should clear it out for you
Username: Plymouth
Post Number: 13
my viewsat work fine on Bev Dish and Globecast
