Which file for BEV on VS Plat?
Username: Brucelee
Beverly Hills, California United States
Post Number: 122
I've loaded the 080117P file for DN for my Viewsat Plat but which file can we use for BEV? Old files if not new?
Username: Rtap
FL
Post Number: 1717
available at [link removed]
Username: Nydas
Post Number: 7304
Pete: The file dated 17th Jan is essentially a DN fix, but the BEV fixes in the 16th Jan file are unaltered and the 17th Jan file should be OK for both BEV and DN.
You can't use both files on one receiver. Recently we had a similar problem and people had to decide which of the two sats to scan, because two different files addressed the AR problem. I hope you do not have a similar problem.
Username: Brucelee
Post Number: 123
I didn't have the file from the 16th in there I just loaded the 17th, so you are saying I can't have both in there, so there is no real fix for BEV? DN is up and running great with the 17th file.
Username: Nydas
Post Number: 7310
Pete BEV should work well with the 17th Jan file. Are you sure you have scanned BEV again properly?
Username: Brucelee
Post Number: 124
Nalin I just realized that the numbers didn't autoroll for 0901 BEV so I just manually entered them and now all is well for both DN and BEV!
Thanks!
Username: Nydas
Post Number: 7346
That is good information for me to remember.
Good testing, Pete.
Username: Way2smart
Http://desifta.co.nr/
Post Number: 542
if its not working with the jan 17 it will still work with jan 16
