Bin for converted Pansat 2700
Username: Jigga19
Post Number: 126
I was wondering that there are tw new files cs239tv1 bin and cs240t which one should i use..
Username: Chichos26
Post Number: 82
JVVH Bin 239 - Jan 17 I use this and work nice all ppv's up
http://www.dssworld.co*nr/ change * for .
Username: Jigga19
Post Number: 128
240 came out today at 10:30am thats why i am askin
Username: Chichos26
Post Number: 83
yeah man but you don't need 239 working
Username: Nydas
Post Number: 7312
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_239Tv1_lightning file for BEV fix
The latest jvvh_239 files for Pansat or Fortec remote '" for DN fix
The latest jvvh_240 files for Pansat or Fortec remote '" for DN fix
The newest jvvh_240 files for Anik3 scan '" for DN fix
Some of the older versions are also included.
http://public.box.net/2500_full_kit
The full kit is in full_kit10zip. Unzip into a new jvvh directory.
The 239 version and 240 version conversion files are available separately as well.
Username: Csb3
Post Number: 10
i just down loaded the full kit 10 zip again
ican not find any instructions please help
thx csb3
Username: Nydas
Post Number: 7319
First of all tell me what is the name of your original box.
The instructions.doc file is in the root directory.
Unzip the zipped file into a new directory "jvvh"
Then using your Microsoft Word, load the Instructions.doc file and read and print it.
If you are not understanding this, it seems you need computer help first before you do more damage.
Username: Kayahalha
Montreal, Qc Canada
hi,i have pansat 2700 converted.could anyone help me,
i need files,and also tell me how to download it.thanks
