121 to 118.7
Username: Koku99
Post Number: 54
How do I change from 121 to 118.7. If I chnaged to a circular LNB would it be sufficient or do I have to move the dish two degrees to the east??? Thanks.
Username: Kirankumar
Kenya
Post Number: 881
if you read some of the posts here you will find a solution ,i have seen a lot of them , good luck
Username: Nydas
Post Number: 7099
Do a google on 118/119 or 118.7/119 and find the appropriate Universal LNB.
Or go to eBay and look there. These LNBs are about $15-25
Username: Koku99
Post Number: 55
Hi Nalin, I have allready purchased the Universal LNB. I was going to install it tomorow. I just wanted to know if I had to move the dish 2 degrees to the east to go from 121 to 118.7 or could I leave the dish as is pointing at 121 and still get 118.7 once the universal lnb is installed. Thanks.
Username: Jurj1
Post Number: 425
No, you will need to move it
Username: Lroy
Post Number: 352
You will have to readjust your dish and also get a Ku band Circular 10.750 LNB.
LNB specs.: L.O. 10.750GHz.
INPUT : 11.70 - 12.75GHz
Username: Nydas
Post Number: 7109
Darshan Raja : You will have to move it. Please post your experience - getting both 118.7 and 119 on one LNB.
Username: Pizza
Post Number: 71
I bought a Circular Single LNBF (Eagle Star pro)
Model No: 53-4553-1
input: 11.7~12.75GHz
Output: 950~2000MHz
L.O: 10.75GHz
Noise: 0.3dB
I got both 118.7 and 119
(I have 36" dish but 33" is enough)
Username: Nydas
Post Number: 7129
pizza: Please post the price and your antenna settings for everybody's benefit. Thanks.
Username: Pizza
Post Number: 72
i bought this lnb for $10.00 but i paid cash.
Username: Nydas
Post Number: 7132
Great price. What about the Antenna settings for it?
Username: Pizza
Post Number: 73
i have viewsat ultra and when go to menu and antenna set up i go echo 7 (119) i did not get 118.7(anik f3) .
i used
LNB Freq = 10750 (10600)
LNB Freq low = 9750
LNB type = universal
22KHz = off
Diseqc Number= LNB3 (i am using a switch on #3)
i used echo 7 then blind scan.
(do not change any settings after you scanned. if you finished scan and if you go to antenna set up yo will see different setting but do not change any thing leave it just like that)
i missed many indian channels. i found tp frequency for that then i go to channel scan i added tp then i did scan for that)
now i have 119 and 118.7 in one lnb
Username: Madflea168
Post Number: 36
little help here, please.
I think I got the 118, but they are all in channel #4000+, the 11715 I try to get did not came back with anything. perhaps need more setting change in the menu with the xtreme, thank you.
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 68
Hi all
I have Ariza 700 I bught LNB For 91.W
I ave satellite T_5 ,110, 119 on one dish and I want to get Nimiq1/ku
Tp 12224 H 20000
LNB power on
LNB Type Standard
LNB Loccal Freg 11250
22KHZ off________on
Diseqc #3
Legacy None
Positioner Setting Disable
Level 80%
Quality 0%
After that I ut TP 12239H20000
Level 81% Quality 75%
I set up it
After that being Data updated 10000
Can some one help me?
Thanks alot
Post Number: 38
a thread I read, I should get some Q @11715, but since I am not, which way I should adjust my dish? the freq I got is pretty much from 11750 and higher.
thank you,
Username: Pizza
Post Number: 75
i did not understant your ?
i think you have to add tp
for example ([ 12245, 20000, V, 3/4 ]) like this
if you find the tp 11715 then do channel scan it
Username: Slb1962
To, Ont Canada
Move the dish to 119, with a circular lnb (freq. 10750)if you blind scan sat you should get both birds.
I have a pansat 3500 sd, 33' dish pointed at 119/118.7, 110 and 101 amc4.
I get all the channels except RTPi on amc4 tp16.
hope this helps.
Post Number: 49
I had another thread on my 118 issue king was helping.
here is the situation and the latest result.
I HAVE DP REPOINT KIT(118/119, 110) REPLACED MY SUPER D 121, IT IS NOT GENERIC.
I could not get the 118 yesterday as I started the other thread asking for help, I thought need to do some adjustment to the antenna, so I went out this morning with tv and stb by the antenna.
and what do you know, the signal was great and 11715 is there with perfect Q, did the scan on the tp, got the channels I want, move everything back in, the signal still there.
BUT after I did a full scan, the 11715 is no longer there, signal is not stable, will not able to lock in.
move outside again, still no luck after so many different setting try just like yesterday.
I do not think the new ecm would affect the signal come in, so what is the problem?
any help is greatly appreciate.
Post Number: 50
btw, my 119 and 110 are pretty decent, I have total of 6~700 channels.
Post Number: 51
what are the chances of getting a bad lnb?
Username: Slb1962
To, Ont Canada
I had the same problem a while back.
It turn up to be a bad switch.
Post Number: 53
I thought of that too, I have dp34. but I even tried with only one sat directly to the stb at a time. for one minute it was there, gone the next.
Post Number: 55
this is soooo frustrating me, last night I have nothing on the signal, this morning, it is there again, just like yesterday morning, and it seems to be as strong as yesterday morning, weak in the afternoon.
now I got the channels all in for the 118 at the correct sid also.
and I still can't figure out where exactly the problem is.
