Where are you chancy?
Username: Webjohn
we need your help to convert the new 2700a file for our beloved FLU
Username: Saqeeb9000
Post Number: 1595
[link removed]
here is conversion kit..
Username: Webjohn
Post Number: 7
im talking about the 239 bin for the 2700 converted for the flu and others alike.
Username: Borinick
Post Number: 100
I think that for 239 are for original pansat not clones John Smith.
Username: Felt
the new jvvh 239 file is out works good on 2500 converted receiver load it over cs files enjoy
Username: Nydas
Post Number: 7273
This post is for converted receivers - NOT suitable for genuine clones.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
In case you have difficulty getting the latest BIN, it is available here.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_237T_lightning file for BEV fix
The latest jvvh_239 files for Pansat or Fortec remote '" for DN fix
Some of the older versions are also included.
http://public.box.net/2500_full_kit
The full kit is in full_kit9Bzip. Unzip into a new jvvh directory.
The 237 version and 239 version conversion files are available separately as well.
Username: Nydas
Post Number: 7275
Chancy 239 Tivo file for genuine clones is NOT available yet.
Do not use jvvh_239 for genuine clones.
Username: Lewis13
KY United States
i have a clone and i am running the jvvh 239 bin and all working on dn for me
Username: Nydas
Post Number: 7286
LEWIS : You have a 2500 or a FLU converted to work like a 2700
A Pansat 2700 clone is manufactured like a Pansat 2700 and has never used Pansat 2500 boot or BINs.
You should know the difference, otherwise you will load the wrong bin on your receiver.
Username: Leo_here
Post Number: 33
WHere can I download a working FLU 2500 - 2700 converted CS239T DN fix??
I downloaded this bin from dssworld.co*nr and my screen goes to black when I try to do a Power scan
Username: Nydas
Post Number: 7289
Leo:
Username: Borinick
Post Number: 108
good afternoon Nalia Nyda i want to know if is already been clone 2700 i have vortex 7700 could i used bin jvvh 239
Username: Borinick
Post Number: 109
because this got me confuse
Username: Nydas
Post Number: 7298
nick: You should not use the words 2700 clone. You have a Vortex 7700 CONVERTED TO 2700
You always use conversion BINs that start with CS_ or jvvh_
Never use genuine BL87 BINs for Pansat 2700.
Never use clone BINs that are "tivo" bins for Pansat 2700 clones.
I have posted the latest conversion BIN info above and you can go there and download the conversion 239 and 240 conversion BINs or the full kit for conversion with latest Instructions.
Username: Borinick
Post Number: 110
thanks Nalin Nyda i should used 239jvvh then?
Username: Borinick
Post Number: 111
then another one for remote .
Username: Nydas
Post Number: 7303
jvvh_239 or jvvh_240. The 240 is said to be better.
Username: Borinick
Post Number: 112
ok i will used the 240 then thanks again.
Username: Nydas
Post Number: 7309
CS_239T_lightning is defective. Use CS_239Tv1_lightning or jvvh_239 or latest jvvh_240 BINs for th econversion 2500/FLU to 2700.
Username: Dishlover
Toronto, Ontario Canad
Post Number: 96
Thanks Nalin.
