What is a good receiver to buy ?
Username: Kirankumar
Kenya
Post Number: 955
Guys,
I am tired of my c00lsat7000 and want to replace it , not very high end but reliable , any suggestions and price range would be helpful. Thanks
Username: Tale
Post Number: 125
If you are NOT looking for HD then Nfusion is the best !
Kenya
Post Number: 961
me ta,
thanks but i want to keep away from that ,i don't really want an internet connection
Username: Frobi
Guelph, Ontario Canada
Post Number: 149
Viewset Pro around $200.00 in Ontario.
Username: Brucester
Post Number: 1028
african go with cw600p got great support easy to us and best of all cost 89 dollers best bang for your doller i had my cw600p for 2 years now i pad 180 for it this summer i got a nother 1 for 125 and my bud got viewsat and im up more then him and it cost him 240at the start of last summer he got a cw600p last week for 50 dollers off usedottawa.com you to can go look you might get a good deal hope this helps you african
Username: Tale
Post Number: 127
...then you can get cheapest one with SD card or USB to get it updated easy way.They are all the same my friend...mather of time to get updates = few hours !!!Don't listen to blah...blah..this one that one ! CHEAPEST !!!
Username: Brucester
Post Number: 1033
me ta what are you saying he is asking for info on ather boxes and he dos not whant nfusion what is your point
Kenya
Post Number: 963
bruce 1,
thanks i will get a cw600p , any goo dealers in US ?
Username: Drmunna
Post Number: 250
Dont know about others but viewsat ultra and CNMini are the ones that i like most...ultra is now under 160 can here in alberta
Kenya
Post Number: 969
Dr Munna,
I need something in the US
Username: Tale
Post Number: 128
Bruce
My point is to save him money.
Since he doesn't want HD or nfusion then he can buy any with SD card or USB to load the bin easy way.What part you don't get ? I would bye cheapest one - that's what I am saying !!!
Username: Rtap
FL
Post Number: 1641
African buy a viewsat or sonicview.both have great picture and support.i know its a little more expensive but its worth it.
Username: Tapeman
New York City in-HD, NY
Post Number: 2155
I like VS Pro
Yo can load using memory stick
Yo can record using external Hard Drive
I won't recommend any HD receiver
Username: Rtap
FL
Post Number: 1645
thanks for your input
Username: Brucester
Post Number: 1034
african i thin you should get the box the best mets your needs talk a day or 2 and read the pros and cons of the boxes then decid witch box you want to get and there are lots of sites in the us that sale cw 89 dollers tax and shiping i think naked girle just got one in the us ask her or him
Kenya
Post Number: 970
thanks, guys because coolsat7000 really kicked my but,I'll let you guys know the outcome
Username: Saqeeb9000
Post Number: 1543
African buy nfusion...see ftatester also bought nfusion now.....................
Post Number: 1544
hi african wait few weeks next bin for nfusion will make impossible for dn to hack your box. b.c i heard next bin will have option to choose the ip adress at whereever you want..
so don't buy another piece of crap like viewsat,pansat,or Koolsat,sonicsat (all crap)
Username: Det
can anyone help me?
Username: Brucester
Post Number: 1040
start a new thread and tell what you need help with
Username: Det
my epg doesnt work and everything is right.i just loaded the new bin yesterday.any solutions?
Username: Det
my epg doesnt work and i downlaoded the new bin yesterday.
Username: Bill038
Post Number: 441
nfusio Kicks AZZ. UP all the time and nothing to worry about.
