Cw600 help please
Username: Kktroyy
Hello can some one please help I am getting 0 quality signal on 148 . I was getting 148 before with no problems but after loading new file 168 it just says signal weak....BEV is working fine...I have already cheked antenna settings and everything looks fine
Thanks in advance
Username: Brucester
Post Number: 1017
need mor info is it cw600p or cw600s what bin are you using
Username: Kktroyy
Post Number: 7
Hi Bruce, Its CW600premium and i am using bin168
thanks
Username: Kirankumar
Kenya
Post Number: 861
khurramkhan,
what are your dish settings , if you post then bruce 1 can help you more
Username: One_eye_jack
Post Number: 189
Turn the main switch off at the back of your receiver. Wait few minutes turn back on.
Also Scan the TPs one at a time,to check for Quality Signal.
Username: Brucester
Post Number: 1018
did you try bin 163 or 164 still working on bev and dish i do not get 148 on my dish it is at 110w and im get all ch on 110 and 91wbev allup with bin 168
Username: Nydas
Post Number: 7064
For some PANSATs and C00LSATs
As of now DN is working fully well using BINs dated around 22-26 Dec 2007.
BEV has put a different type of ECM causing the older BINs mentioned above to work properly on even channels and the latest BIN to work on odd channels
Similar situation might apply to CaptiveWorks
Username: Brucester
Post Number: 1019
not on my 2 cw600p on sume ch it is talking a bout 10 sec delay for on sume ch not all but cw did comw out with new bin on the 01-11-08 to fix this and all dish ch are working good fast ch chang and 1or 2 tims a day it frezzes up for about 30 sec cw is dowing a great job for the past2 or 3 ecm
Username: Cb1000
Post Number: 19
I got a new cw800s its working great with latest bin, the problem i have is the remote is weak, i have to aim it directly at the reciever or it wont work
Anyone else having a problem with cw remotes?
Kenya
Post Number: 873
CB,
have you tried new batteries?
Kenya
Post Number: 874
also if there is a plastic film on the front of receiver , remove it
Username: Cb1000
Post Number: 21
I put two new Energizers in it, and have already removed the film, but its the same.
I'm only 8 ft away from it too, if i aim it one foot to the left or right it won't pick it up.
Kenya
Post Number: 894
CB,
seems like you have bad remote ,try getting a new one on ebay.good luck
Username: Brucester
Post Number: 1021
all cw remotes are like that i think there is a new unverstail remote for cw and it works real good but if you take the batteries out and put them in the wrong way put remote in other room for 15 to 20 min this will help mack it stronger then put them back in the right way i did it and it made my remote work better you can try it no harm can come from it have a good night
Username: Cb1000
Post Number: 22
I'll try the reverse battery and see
Also every time the keys update a popup comes on screen tells you so, is this really necessary, is there a way to stop it?
Its not a big deal but when recording a movie you on't want that in there
Username: Brucester
Post Number: 1023
goto the menu system setting system key updat message turn it off
Username: Cb1000
Post Number: 23
bruce, African...Thanks
I was able to turn the message off
I tried reversing the battery but didn't help, I think i might get the one on ebay for 25 they claim its stronger
