DN and BEV ECMs are different today
Username: Nydas
Post Number: 7065
For some PANSATs and C00LSATs
As of now DN is working fully well using BINs dated around 22-26 Dec 2007.
BEV has put a different type of ECM causing the older BINs mentioned above to work properly on even channels and the latest BIN to work on odd channels
Username: Hshakarchi
Post Number: 193
if this is the case, and you have two receivers, put the EVEN BIN on one and ODD BIN on the other then flip between each other.....!!
Username: Nydas
Post Number: 7077
This is BEV's attempt to bring Canadian husband and wife together when they have two receivers in different rooms!!!
Username: Mcrabbycabby
Wpg, Man Canada
Post Number: 27
thank you nalin so i have to just wait.for something else?
Username: Rzkaps
Toronto, Ontario Canada
which bin is working? Can you give the number and where to download it from?
Username: Kirankumar
Kenya
Post Number: 868
Rashida,
go to [link removed]
all the new files are there.
good luck
Username: Aksma
Post Number: 46
Please help!! I have tried with bin 233 and also 235. But No channel is working all says scrambled?? Any clue???
Thanks in Advance
Username: Aksma
Post Number: 47
African, none of those are working for my 2700A. I used 233 and 235 both not working...
Kenya
Post Number: 870
are your settings good?
Username: Dude123
Post Number: 1807
bins 231 to 234 are all working good for pansat 2700, if you are having some problems then check your settings
Username: Mike73
Post Number: 37
im using 232 Leafs works great
Kenya
Post Number: 871
Achsah,
you can get bins 231 or 234 at [link removed]
good luck
Username: Leafs
Post Number: 349
all working bins are posted at www.ftasolutions.blogspot. com
Username: The_coders
Post Number: 55
all working bins are posted at http://www.amishrakefight.org/gfy/
Username: Aksma
Post Number: 48
African, you mean 231 or 234 are working ?? for 2700A?? Please let me know.
Thanks
Username: Dude123
Post Number: 1812
Achsah,
231, 232, 233 and 234 they are all working good
Username: Dude123
Post Number: 1813
so if you have any of those four bin file load it and watch TV and if you don't have any of those then go to [link removed] to get the files there.
Username: Hangon
Post Number: 14
I have loaded 233 and I only get even on Bev, then 235 and receive the odd. I have not used the 234 file, does it work better than 233 on Bev? Pansat 2500a to 2700 convert.
Username: Nydas
Post Number: 7110
The 234 file works the same for DN and BEV as 232 and 233. It works better for GC. That is the only difference.
