Recent DN Changes
Username: Runnerguy
Pluto
Post Number: 1037
C/P
1/9/08
Channel 157 became "OVATION" as reported on 1/7. IMF is history on Dish.
"INFO" channels telling subsribers to Columbus OH, Dayton OH, Charleston/Huntington WV and Charlottesville VA local channels at 105° that they will be moving to 129° and to call Dish now booke-end each local market. There is really only one channel mirrored many times. The Info channel is mirrored on channel numbers 7199, 7208, 8314, 7326, 7424, 7432, 7928 and 7934.
WKBS Altoona on channel 7472 moved from tp 29 spot 9 at 110° to tp 1 spot 3 at 119°. Johnstown/Altoona locals have been split between these two transponders for some time. This move was probably to better balance the load on each transponder.
After only 10 months, Dish decided to change the call letters on channel 9219 (WTVK) to WXCW. The change occurred May 2007. (Raymie)
655 WOW TV, 716 VIDIT, 815 RCORD, 817 SPT are the next international channels to go to a slate telling subscribers the channels are leaving 61.5°, 121° and 148°. All have temporary homes in the 5700 range for the transition so subscribers do not lose service completely until they get the new equipment necessary to receive 118°.
The transition for the following channels is complete and the 61.5°, 121° and 148° versions have been removed from the system. 705 ARANG, 739 RTVI+, 747 ARYOW, 795 SUNTV, 908 RAD60, 909 RADIT, 910 RAIRD.
Username: Saqeeb9000
Post Number: 1513
ARYOW, 795
zulu is this channel removed from 148?
Post Number: 1514
Post Number: 1515
bump
Username: Runnerguy
Pluto
Post Number: 1038
Do the best of my knowledge it has been removed from the system.
Post Number: 1517
so where is it gone? to which dish?
Username: Runnerguy
Pluto
Post Number: 1039
I think it shifed to 118 and for some reason it cut off.
Username: Vittu
Post Number: 109
I am using 118 and I can I confirm, I have ARY One World.
Post Number: 1518
so in order to get 118 u need to move dish.. i mean 119 and 118 are really close .. so how do 118 get the signal's.. its just 1 degree difference.. can any one tell me how i do that?
