2500 pansat
Username: Saado7
Post Number: 20
when i turn it off then on with the remote it starts like i've reboot it with the b-75 on the screen . does anyone have this problem ???
Username: Nydas
Post Number: 6802
The latest Chancy version CS_235T_Lightning recognises power off (using the remote) as a complete OFF and not a standby.
Username: Saado7
Post Number: 21
so it's a bin problem thanks for the info.
Username: Nydas
Post Number: 6805
You can try using
Jvvh_PansatRemote_235.bin
Username: Pepaws11
Pendleton, SC USA
Post Number: 7
where do i get the 293t or the 294t bin file?
Username: Nydas
Post Number: 6847
Most sites have them under Fortec Ultra or Pansat 2500 or Pantec section.
Username: Hamid9272
Post Number: 25
expressfr.com at clone section
Username: Hangon
I am getting Level 31% Quality 0%. No signal. It was working last night, what's up?
Username: Pepaws11
Pendleton, SC USA
Post Number: 8
which site might that be for the 293 or the 294t, expressfr is in french!
