Any one tried the new bin at total fta yet???
Username: Bjcrisp6478
Post Number: 148
i wonder if it is the real fix????
Username: Ke5aqn
Post Number: 2953
what receiver?
http://www.thetotalfta.com/ has no bins on fist page yet..other one has bin's from last year not new bins
watch the date of the bin
Post Number: 150
the viewsat xtreme...i had done installed it what can i do to fix it ????
Username: Ke5aqn
Post Number: 2956
fix it? what did it do?
Username: Viewsat_ultra
Post Number: 17
FTA Tester, The link that you provided is the "real" site and TotalFTA is the fake and shouldn't be trusted, correct?
Thanks
Post Number: 151
it the same as it was before i installed the bin from thetoatlafta...... it it mess it up with an older bin ???
Username: Silvermir
Post Number: 20
THE FTA TESTER
Username: Ke5aqn
IF I DONT KNOW THE ANSWER , I WILL FIND IT FOR YOU !!
Post Number: 2953
Posted on Thursday, January 03, 2008 - 02:13 pm:
what receiver?
thetotalfta now has the current bins on the frontpage
we're still waiting for the rest of the viewsat bins
Username: Ke5aqn
Post Number: 2968
Post Number: 153
what can i do if i have already put the old bin in my reciver??? will it be ok or did i mess it up??? sofar it still the same way it was before i did anything to it....i hope i'm good and didn't mess it up
Username: Ke5aqn
Post Number: 2972
read this and follow its suggestions for the easiest way to update..
Post Number: 156
i read that but how to you get back the channels you hav already lost ????
Username: Ke5aqn
Post Number: 2974
Do you mean they are now deleted?
I would sugest you do a factory reset and then install a new satfile or blind scan each sat you can receive..after you adjust all your antenna settings..then make a backup satfile and channel list
Post Number: 157
k can you please waLK me though it... wher can i get a new satfile from and how do i do a blind scan???
Username: Ke5aqn
Post Number: 2979
I did in that guide....what is your receiver?
Post Number: 158
viewsat xtreme
Username: Ptaha
Post Number: 45
it says vs extreame and such are down wtf?
Post Number: 159
fta tester i have a viewsat xtreme
