Can VS extreme work with key manually?
Username: Domy
Post Number: 70
can VS extreme work with key manually?
is so how ? i dont see 00 and 01
Username: Aelhage1
Post Number: 8
Now depending on what key sets are to be changed. Usually displayed to you as follows:
Key 00 00 00 00 00 00 00 00 00
Key 08 - 06 07 F0 E2 61 6F E1 45
Key 09 - 01 C5 FB 21 37 B6 C0 5E
Key01
Key 88 - 06 07 F0 E2 61 6F E1 45
Key 89 - 01 C5 FB 21 37 B6 C0 5E
(Means keys 08 &09 need to be changed to the following)
Using your remote Arrow Buttons to navigate to the specified key to be changed enter in the new keys. Use the following to enter numbers and letters:
Numbers are 0-9.
Letter A is Button F1
Letter B is Button F2
Letter C is Button F3
Letter D is Button F4
Letter E is Button LAST CHANNEL
Letter F is Button TEXT
Once you have entered both lines need verify your entry and Hit the Exit Button.
You will then be prompted to save your information. Highlight Yes and hit OK button on your remote.
Now just keep hitting the Exit button on remote till you get out of all menus and if you have entered in the keys correctly you should now have picture back.
Username: Mikdadog
Put the new keys into my VSX and voila! TV!
