How to restore lost channles ALL Receiver's
Username: Ke5aqn
Post Number: 1892
If your receiver is missing channels now do this and you should get them back
With new Bin's being released so often so many of you are losing channels during the updating process.. To save alot of time I thought I would post a few suggestions of what you should do before or during the updating process every time you upload a new bin in your receiver.
I do this each time and never have any data loss I just do it this way, in this order, and watch tv seconds after putting the new bin in my receiver not after fighting my receiver for hours or day's.
#1 BEFORE you disconnect your receiver from the TV make a note of ALL antenna settings for every Satellite you can receive. You could do this ANYTIME so its done. I have it all in nice text DOC in my computer.
#2 Download the new bin from the "home" forum for your receiver. Never pay for free info. Unzip the file and place it inside a folder on your computer named "new bin 12-03-09 or whatever the date is.
#3 Go to Viewsatusa.com or wherever on the nett you can get one and get a FRESH UPDATED copy of the satfile. Place this file inside that folder you made today.
#5 Use the Loader Program or USB drive to copy the channnel list FROM your receiver to the computer. Place that file indise the folder you made today.
#6 Use the loader Program or USB drive to install the new bin, satfile, and Channel List from the folder you made today.
#8 Connect your receiver back to TV, LNB and whatever else you normaly do.
#9 Using you notes make sure all settings are the same as before in each satallite you can receive in antenna settings.
#10 Turn it to a sat and if need be let it autoroll. Sometimes this step takes 3 min sometimes 10. If you interrupt it by changing channels it will take longer so just let it roll.
#11 Watch tv. Be thankfull it works.
#12 After using the receiver for a while go to the "home" forum for you receiver and report any Bug's or thank the coders for their hard work.
Yes their are a few extra steps here than what some people will say do they do but when these steps are done they save ALOT of time and energy fixing trouble after a data loss. I have 17 sat's scanned with 2700 channels it would take me about 5 hours to get everything back the way I like it. I am sure others will jump here and say stuff like "I never do all that and I never have troube" That is fine I am just saying if you do this you will not have trouble due to data loss or settings being wrong. It takes me about 5 min to do this each time so its not a big deal. Upload
Username: Ke5aqn
Post Number: 1941
bump
Username: Ke5aqn
Post Number: 1957
Bump
Username: Ke5aqn
Post Number: 1977
Bump
Username: Scabz
Knoxville, Tn Us
Post Number: 147
What if you can't figure out how to save channels to your zip drive ? I have a viewsat ultra.
Username: Ke5aqn
Post Number: 1980
I would recomened you use the cord and loader 2 ofr that then. Their are lots of how to's on the home forum's for each receiver on how to use the USB drives..
Username: Ke5aqn
Post Number: 1986
Do this also if your receiver is on a channel and "autorolling" forever and not receiving the channel. That means your channel list is still on the recever but the transponder is lost from the sat file. Yes that happens.
Unless their has been a NEW ECM and EVERYONE is reporting lass of Movie channels, Internationals, PPV, etc...
Username: Ke5aqn
Post Number: 1991
bump
