Looking for in-put
Username: Gwr5
Us
has anyone ever heard of / or using an INVACOM quad qph.031 lnbf. if im reading correctly it gets 119,110,121,61.5,148, plus on one lnb at same time. without a motor. thnx
Username: Tapeman
New York City in-HD, NY
Post Number: 1960
can get you all FTA and PTA satellites with a motor
plus the new 118 FSS
But must use a motor to a simple 30" dish
Username: Gwr5
Us
i was checkin out there add and they say it works on fixed dish. i found that hard to believe. invacom is pushin these lnbs on flebay. thnx for infoUpload
Username: One_eye_jack
Post Number: 109
The Invacom QPH-031 does work on fix Dishes,
either you have read it wrong or someone has lie to you.There is no way it will get
61.5 and 148 without the motor.This LNB is mostly used on motorized Dishes.
Username: Gwr5
Us
i was looking for info on it. is it worth using and if so, whats the best dish set up to use?
thnx
Username: Joeturn
Post Number: 96
Needs motor and stay off ebay
http://www.emantechnology.com/store/pc/viewPrd.asp?idcategory=8&idproduct=54
Username: Joeturn
Post Number: 97
no sales pitch here
http://www.mxmart.com/index.php?main_page=product_info&cPath=3&products_id=130
Username: Joeturn
Post Number: 99
This one looks awfully familiar to me
http://www.mxmart.com/index.php?main_page=product_info&products_id=126
Username: Gwr5
Us
joeturn. thnx for the linx\
