Pansat 2700A Problem
Username: Laxey34
Miami, FL United States
Post Number: 28
Hey Guys! I load on bin 227 on my original Pansat 2700A and now is only showing signal level at 99% on almost all transponders but no quality. Sometimes it will come on but not on all transponders. The strange thing if I put it at AMC4 it shows ok on that satellite.
I know it in not my connection or switch for I have another Pansat 2700A receiver and when I hook it up ... no problem ... it shows, I watch cricket up to this morning (India/Pakistan). I did a factory reset and load on the original Pansat bin 120 and I reload the 227 and same thing.
I even do a receiver to receiver upgrade from my other working pansat 2700A. The receiver come on ok and as I said I can get the FTA channels on AMC4 without no problem but not dish on 110/61.5W. On 61.5W after a while it will show some of the channels on TP 12414, the TP that 3ABN is on, (12355 i think), 12384, and that about it.
What could be the problem and what can I do? Any ideas?
Username: Nydas
Post Number: 5868
Are copying the User setup and antenna setup of the working Pansat 2700 to the not working Pansat 2700?
sometime people tend to forget the need for doing user setup and date/time/time zone - which is needed for the system to work.
Username: Laxey34
Post Number: 29
The system work on FTA on 101W but not on Echo 8 or 3. It was working before I put on the 227 bin. I am getting signal but no quality.
Username: Joeturn
Post Number: 67
then you sir have your wires crossed 101w is no longer detected by dvb
Username: Nydas
Post Number: 5873
greggor :
With the working receiver, what are the Antenna settings?
How many and which sats are showing as selected?
Please give specific answers to these two specific questions - no other talk.
Username: Dragonfly2
Post Number: 19
what is the latest bin file for a converted 2500A?
Username: Joeturn
Post Number: 68
What posessed you to load the 120 bin and then to skip the b-75 update??
Username: Nydas
Post Number: 5874
joeturn:
That was an astute observation.
All the current Pansat 2700 BINs 201 onwards require that you instal b75 boot.
Username: Dimwitt
Post Number: 288
Pansat 2700A_070310_B75_120_api.bin
Username: Laxey34
Post Number: 30
Guys! 101W is AMC4 (the christian channels) not DTV. I have 2 Pansat 2700A. One is working fine the other does not. Both receiver setup is identical. Both use the 227 bin. Receiver (A) is working on 101W (AMC-4) and 110W and 61.5. There is no problem with the switches or cable. Receiver (B)has the same setting, 227 bin but have signal on everything at 99% (which is not the true signal level) but no quality.
If I switch to AMC4 at 101W after a time it will work for example on 3ABN, Hope Channel, LLBN and so on. If I put in on 61.5W (Echostar 3) will will work after a while on TP 12355, 12414, 12472 and no other TP which I find strange. It will work on some Echo 8 TP as well.
Anyone have any idea what is the cause and how can it be fix?
