Samsung SRV-960 VCR
Username: Bobha
Post Number: 30
i have two almost identical samsung vcr's with the same fault when you press the power button it lights up for about 3 seconds then switches off the only thing i could think of is our little boy has a habit of switching stuff on and off could this have tripped something out?
Username: Englishman62
HamburgGermany
We had problem once with our remote control, where Coke was spilt on it. One of the buttons was stuck down, causing it to intermittently switch the hi-fi off. Try cleaning the inside of the unit. Just a thought.
Need to Register?
Forgot Password?
Enable HTML code in message
