Just looking for a little advice...
Username: Adale
Post Number: 34
Hey all - I am looking to get a 2nd receiver for my home and curious as to what everyone thinks is the best.
I currently have VS Xtreme and have had a Pansat clone ( which no longer works ) and other then thoes 2 receivers I am clueless as to which other are good to deal with. Also if any of the others have clones - which ones and how to spot them.
Any advice would be appreciated.....Thanks!
Username: Teevee4me
Post Number: 27
I would like some advice also on which brands have the clone problems and what models too. Thanks
Username: Brucester
Post Number: 717
i think the best box for your money is captive work the cw600p got great suportthis round cw did not go down all this for less then 100 best bang for the buck
Username: Adale
Post Number: 35
Ok great, thanks....Does the CW have a clone box out there?
Username: Extremex
Post Number: 19
I would suggest you look into the NFusion.
Username: Rtap
FL
Post Number: 1323
I WOULD GO WITH VIEWSAT,SONIVIEW
Username: Adale
Post Number: 36
Do the NFusion and the Sonicview have good support and do they have clone boxes?
Username: Adale
Post Number: 37
Do the NFusion and the Sonicview have good support and do they have clone boxes out there?
Username: Extremex
Post Number: 20
Know known clones for the NFusion. Which is a good thing. NFusion normally up within a couple hours via IKS.
Username: Extremex
Post Number: 21
Keep in mind also that Viewsat and Sonicview are currently being sued by Eccostar.
Username: Adale
Post Number: 38
Ahh okay thanks! Yeah im not looking for a clone - had one and would like to stay away from them! lol
Username: Adale
Post Number: 39
Viewsat and Sonicview are being sued?? I didnt know that... So what could be a possible outcome from that situation??
Username: Funtoy
Pansat is also being sued.
Username: Extremex
Post Number: 22
Its actually quite old news.
http://www.multichannel.com/article/CA6462380.html
Same thing with Pansat
Username: Rescate
VENEZUELA
Post Number: 34
Dayle,
I have a Pansat 2500a Clone, 100% UP,
First time I flashed went OFF after 3 days, no lights, nothing.
Then was JTAGGED (a simple software direct flashing method) and everything was OK, flashed every time since then, no problems at all.
I also JTAGGED a Fortec Life Time Ultra clone, same problem, same procedure, IS STILL WORKING fine.
Thing is if you are carefully and like to learn, you can have ANY receiver.
A friend buy a VS 2000 Extreme paid 200$+tax, know is afraid to flashit BECAUSE those receivers ARE DELICATE and EXPENSIVE, and if you DAMAGED by flashing it with a WRONG bin, then there is NOT GUARANTEE.
Any receiver you FLASH with an NOT AUTHORIZED bin LOSSES ITS GUARANTEE.
So with this info on hand, take your decision.
PD. A friend ask the store he wants to have a good receiver instead of a clone he Got a NORSAT 7500a, WOW what a DEAL (jiji, I FLASHED AS A VULGAR PANSAT 2500a CLONE) it was really a PANTEC MS+ or something, with options for Fortec or Pansat.
Username: Adale
Post Number: 45
Thank you Rescate! Great advice and much appreciated
