Bronze Member Username: New_member098Post Number: 22 Registered: Mar-07 | Experts, I'm trying to get 110, 119, 129 and 61.5 sats with 4 lines (receivers) output so that I can watch any channel from any sat from any one of the 4 rooms. To make things little complicated I need to combine signal from local HD antenna (Trek55) so that I can watch local HD channels. What will be suggested configuration? Your expert opinion is appreciated. LK , King any one? |
Bronze Member Username: New_member098Post Number: 23 Registered: Mar-07 | Any one, who can answer this? What DISH, Which DiseqC switch, multiswitch, diaplexer I need to use to make this work the way I want. Currently, I have one 4*1 DiseqC, one 4*8 multiswitch (DTV compatible), one 1*3 local antenna line splitter, three diaplexer to join antenna signal with DN signal, 1 DTV slimline DISH with 4 lines, 1 DTV phase 3 dish with 1 line. Can I reuse any one of the component? Any one LK, King, Nalin, SatScanner, RTAP??????????? |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 914 Registered: Sep-06 | Is putting up 4 dishes with motor's and universal LNB's doable for you? Just getting 4 out of the 17 sat's I can get here with a motor and LNB that receives both DBS and FTA is making you miss out on ALOT of good channels..... |
New member Username: HshundaUnion city, Ca Usa Post Number: 8 Registered: Jun-06 | how i can get 154 NFL channel |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 915 Registered: Sep-06 | Now in order to do what you doing it will take some work. It is hard to get DN or DTV switches to work properly with a FTA receiver. You usually have to have a old DN or DTV receiver connected as well so the correct voltage will be sent to the switch. You could loop from the 1st receiver to the next and so on......but, the trouble will be only one receiver can control the diseqC switch so all receivers have to watching channels on the same sat. It MAY be able to be done the way you want but it will be a fight. I can help ya find "deals" on the proper dish, motor, and LNB's if you want most sellers will give a deal when buying more than one so it wont be that bad...takes no time to set up its easer than all that switching you have already done...I just today set up a viewsay plat, dish, lnb, and motor it took 2 hours to run wires, install the dish to pole, and put new bin and channel list in the receiver, then point the dish...easy Hope that helps ya |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 916 Registered: Sep-06 | Harminder, Please start a new thread with new questions next time. 154 is easy its on echostar 7 at 119W I am watching the game now HOU 10--CLE 7 |
New member Username: RabaabPost Number: 5 Registered: Nov-06 | Hello I have fortec CLASSIC NA receiver. Can anyone tell me do you get dish channels(international channels)in this receiver Thanks |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 917 Registered: Sep-06 | Rabaab Please start a new thread |
Bronze Member Username: New_member098Post Number: 24 Registered: Mar-07 | Let me ask my question in parts - Here is first part --> Which dish I should use in order to get 110, 119, and 129 with 4 lines of output for 4 receivers? |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 922 Registered: Sep-06 | well ok You cant do what you saying if i understand you right you can find lnb's with 4 outputs and have 3 dishes pointed...Give me a min I will make a digram of that for ya....stand by LOL |
Bronze Member Username: New_member098Post Number: 26 Registered: Mar-07 | Can I get atleast 110 and 119 with two Dual LNB that is 4 wires in all that will feed a 4*8 multiswitch? |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 923 Registered: Sep-06 | is the dual LNB a dish500? |
Bronze Member Username: New_member098Post Number: 28 Registered: Mar-07 | That is my question? Which Dish can give me at least two sats 110 and 119 with 4 wirers in all? Currently, I have a DTV slimline that give me 4 lines that goes to 4*8 multiswitch so that I can get both sats up to 8 rooms simultaneuosly. The problem is with slimline DTV dish I can only get 110 or 119 not both. |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 924 Registered: Sep-06 | the way those dual lbs work ( at least the dish500 I know for sure) is they have a switch inside the lnb so i dont think you can use them with 4 different receivers...you will have to have different dishes or at least lnb's pointed for each bird you want to get..a mulitswitch can be used to make a lnb go to more than one receiver....their is a dish-lnb set up that can get mutilaple sat's using one dish very hard to point I have heard I always just use a dish and motor |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1833 Registered: Oct-06 | DTV 3 LNB picks up only from 2 side LNBs The middle LNB does not pick up more than one or 2 TPS DTV TPs are designed different from DN TPs despite similarity in their same polarity The problem is a switch block in circuit board |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1835 Registered: Oct-06 | 6x8 Switch Or Cascade your own like this diagram |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1836 Registered: Oct-06 | This is an easy setup for 5 Sats: 22KHZ OFF to first 4 and 22KHZ ON to #5 |
Silver Member Username: Pannu16Post Number: 541 Registered: May-06 | king is right!! U can use DP34 switchs and 3x4 switches need power too so u gotta get one with power!! I have exactly same setup~!!! |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1837 Registered: Oct-06 | This is also an easy 8x1 Switch setup Sats 1 to 4 select 22KHz ON Sats 5 to 6 select 22KHz OFF If this doesn't work try: Sats 1 to 4 select 22KHz OFF Sats 5 to 6 select 22KHz ON |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1838 Registered: Oct-06 | 4x4 multiswitch Is for 2 satellite connecting 4 recivers |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1839 Registered: Oct-06 | I found this link on yahoo Great source for switches |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1841 Registered: Oct-06 | SW-64 SW64 Automatic Multi-Dish Switch - Three Dish Four Receiver Automatic Dish Switch - connect up to four receivers to two or three dual LNB dishes, or to one DISH 500 dish with two dual LNBs and an additional dual LNB dish. Uses include adding another dish to an existing DISH 500 system for reception of foreign or HDTV programming. BOX SW64 Switch. This switch will allow you to pick up 3 satellites. (119, 110, and 61.5 or 148)This switch will work with ANY model Dish Network receiver. Uses SW64 switch, Power Inserter, Power supply. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1842 Registered: Oct-06 | DP34 This Switch Combines 3 Orbital Locations to power 4 Receiver Outputs -Three inputs to capture signals from three satellite orbital locations (61.5°, 105°, 110°, or 119°) -Four outputs for connection to four receivers, -Three direct feeds to connect to other DP34 switches. -Up to three DP34 Switches can be connected to run up to 12 receivers. -Switch is usually powered by receiver. But may require additional DC power Source. Thak yo Pannu |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1843 Registered: Oct-06 | SW34 Allows you to receive signals from one satellite and Local TV antenna, combining them and connecting up to 4 receivers. Works for all satellite system, e.g. DN, BEV system, DTV, and StarChoice, etc. No power supply is required as the IRD's voltage is passed to the desired LNB. |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 926 Registered: Sep-06 | All those switches and you still only get what 3 or 4 sat's? I get 17 sat's with ONE dish...... |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1844 Registered: Oct-06 | Fo more cool switches click here: https://www.ecoustics.com/electronics/forum/home-video/322149.html For Over The Air Antenna (OTA Antenna) Click here https://www.ecoustics.com/electronics/forum/home-video/330353.html |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1845 Registered: Oct-06 | I'm giving different choices Sometimes these multi receiver switches don't work with certain Satellites or combination of selective ones I personally like to cascade my own I don't like motor at all I can't stand the delay for channels search |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 928 Registered: Sep-06 | so just wondering what would be the end cost on that set up to get all 17 sat's? |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 929 Registered: Sep-06 | I found that dish wf-t90 and based on prices on that site HERE I come up with around $480.00 to get what I am getting and I spent $100 nice to know |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 930 Registered: Sep-06 | Wait...I forgot all the switches to get the receiver to "see" all those LNB's add what another $100-200? to make it $580 or $680 compared to one dish, one motor, one lnb...$100 |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1847 Registered: Oct-06 | Right Yo a got a motor $50 and $50 dish I spend about $50,000 on electronics a year In 1990 to 2001 I spent about 1,000,000 USD on electronics Electronics Hobby to me is Priceless |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 931 Registered: Sep-06 | I am a ham so we tend to make antenna's so I made a dish I found work fine..it did need a motor and a lnb I traded for the motor and bought the lnb so yes I have around 100 in my system..including receiver..some of us dont have unlimited funds for toy's I live in the real world with kids, bills, mortgage and other hobbies to pay for as well... |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1849 Registered: Oct-06 | Anyway The main question is...What would yo do for 4 receivers? |
Bronze Member Username: One_eye_jackPost Number: 33 Registered: Nov-07 | Boy I would like to see a house with 8 dishes It would be a sight to see. I would think parts of North America wouldn't allow that type of installation. Jay keep in mind only few will try. Even most of the the Pros will not install a motorized system. I have called few installers and I was told they didn't know how or had the time to mess with it. Well I gave it a shot and now I can scan in little over 1,000 channels. I really had no choice. It wouldn't be fair to my wife or my neighbors to install 3, 4, 5, 6, 7, or 8 dishes on my roof. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1850 Registered: Oct-06 | 8 Sats in many cases don't require 8 dishes For example 110/119/121 or 118 can be one dish 82/91 another dish 61.5 and 77 one dish 129/127/123/121/101/97/93/45/30 can be all on one motor dish With 4 dishes yo can own entire sky |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 937 Registered: Sep-06 | I have installed or helped with the install of several sat systems. I have had 10 foot dish, had at one time 4 dish500's on poles...the 31" on a pole with a motor is the easiest to install of all of them....you point it south, set the tilt using settings easly found on the internet, and usually the sat's just come right in using USALS in the receiver menu....the last one we installed took about 2 hours from unboxing the dish to scanning the birds.....we got 12 sat's.. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1851 Registered: Oct-06 | I understand Multiple receivers situation What would yo do if yo got multiple receivers and want to watch 2 different programs from different satellites at same time? This is the original question to this thread? Motor is not an option to standard service to Star Choice, BEV, DTV or DN The right way is fixed dish and multiple LNB and Switches Motors good enough for one receiver, one Satellite at a time Yo pick what is best for your quest |
Bronze Member Username: New_member098Post Number: 29 Registered: Mar-07 | Having motorized DISH option is good and I would explore it in more details later, but for now I'll go with two DISH each with dual LNB feeding to a 4*8 SWA48 switch with 4 line of output for 4 rooms (I need to test if this switch can work with DN). I'm planning for 1st dish to point to 110 and second dish to point to 61.5. I think they have enough channels to engage me. |
Bronze Member Username: One_eye_jackPost Number: 35 Registered: Nov-07 | Mr. King Yes you can watch 2 different programs from 2 different satellites at the same time.(Echo 7 & Anik F3) (Hispasat 1C and 1D) (Rainbow 1 and Echo 3)Untrue on a motorized system you can connect more that one receiver. Only the main receiver will control the motor if you know how.Needless to say the rest of the receivers will only receive the channals of the bird that main receiver is set on. BetweenEcho 7 and Anik F3 there is over 500 channels for a family member or guest to choice from.When lot of people check into a Hotel or Motel how many channels do you think they have to choice from. BTW if Charlie & Bev turn the lights out, how much work will it take to move and add dishes for these FTA Satellites Mr. King? |
Bronze Member Username: New_member098Post Number: 30 Registered: Mar-07 | So what one might have to do to install motorized DISH? Which receiver and what kind of wiring (cable and Switch) will work for this setup? Do we have a installation guide or manual for such installation in forum?? |
Silver Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 938 Registered: Sep-06 | The best set up would be a 31", the QDH-031 LNB, motor, and one ditic switch mounted on the dish pole for each receiver. Cost of each dish is "around" $150. The disc switch you will need should have came with your receivers so you should have those right? Set up would be easer than trying to get 4 receivers to use the same dishes. This set up would get you ALL the sat's FTA and DBS so you would ALWAYS have TV even when DN and BEV are off... |
Bronze Member Username: One_eye_jackPost Number: 38 Registered: Nov-07 | KING TAPMAN What was that you were saying yesterday about the motorized dish? I have close to a 800 channels to watch free of charge How many do you have? |
Bronze Member Username: ManusharmaPost Number: 11 Registered: Jun-06 | Quick Q... If I have a dish pointing to 110 , can i replace the lmb with a dual lmb and get 119 as well without physically moving the dish? thanks |
Gold Member Username: NydasPost Number: 5336 Registered: Jun-06 | You can put a second LNB on a bracket for 2 LNBs in front of a 20" elliptical dish. You can also mount a Twin LNB, which would scan 119W and 110W from a single LNB, but with FTAs sometimes you have headaches trying to set them up. The word dual LNB implies a single LNB with two outputs of same sat for two receivers. You can mount two duals on a single bracket in front of a 20" Elliptical - Each dual will feed two receivers so you can get 119W and 110W on two receivers through two switches. |
Bronze Member Username: ManusharmaPost Number: 12 Registered: Jun-06 | Thanks Nalin I could use a Twin LNB for the 110 and 119 but would i need to move the sat or allign it differently...it is currently pointing towards 110 |
Gold Member Username: NydasPost Number: 5339 Registered: Jun-06 | Probably minor adjustment. A bracket and a dual 119 LNB would be a better choice with a 4 to 1 DiseqC switch. |
Gold Member Username: NydasPost Number: 5340 Registered: Jun-06 | Manu Sharma : If you were thinking of getting 118.7 Anik with all the Indian channels, it is a special 119/118.7 LNB (about $20)and a 30" dish is required. |
Bronze Member Username: Ragi48Flushing, New york Usa Post Number: 16 Registered: Jun-06 | Hello Nalin: What is the special LNB you are reffering to for 119/118.7 satellites. thanks}}} |
Gold Member Username: NydasPost Number: 5358 Registered: Jun-06 | Mike Reddy: http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=COLtq4W ng5ACFQltZQod8TDDtA http://www.usedottawa.com/classified-ad/4408471&category=tvs All dealers tell me that although it is KU band, you need 30-33" dish. |
New member Username: Tv906Post Number: 4 Registered: Nov-07 | Hello helpers, Is there any kind of LNB (uninversal LNB) which can gets multiple types of signal from difference satellites? ***For example: use 1 dish, 1 LNB, + motor to get DN channels and a FTA channels like from EchoStar, AMC and IntelSat (the point here is only use one LNB and motor) I appreciate your help and infomation. TV |
