Panset 2700a not working.......
Username: Mazharkhan
Barrie, Ontario Canada
Dear All,
I have panset 2700a and have 224 bin. But it just shows few of channels instead of all. We scanned it several times but same problem. Is there any other new file available or i need to check its settings. Pl guide.
Thanks.
Username: Chrisduclo
Post Number: 107
you should have a couple hundred channels working right now if you are pointing to 110 and 118. but if you are looking for dish international then yes most everything is down.
Username: Ke5aqn
Post Number: 1122
what do mean by "shows few of channels" if some channels are doing autoroll its a new bin you need rescanning will not fix that..like all of us we are waiting....
