LK,Nalin,AV and other people with expierience help me.
Username: Cricket674
Post Number: 144
I need help. my converted pansat 2700 (2500a to 2700) isn't working. it says scrambled or bad channel
I am using CS_224T_Lightning_100t_Series_serial. I am pointed at 61.5. Do i Have to wait for another bin. Do I ahve to wait for updated keys
Username: Pulp_fiction
Post Number: 250
New ECM U need to wait
Username: Tvhammer
Post Number: 33
Thill just get a box that works at GetDss.com auctions
Post Number: 263
your a spammer scammer all korean crap down
Username: Mrsofty
I noticed They Started a thread about thill1951
Username: Nydas
Post Number: 5317
Bobby Joe: If you just want to make sure that the basic conversion is working, try a "W" channel on Echo 7(119) or Echo 8.1(110). The new ECM is mainly affecting the Internationals.
Username: Rah
New York, NY USA
Post Number: 16
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1329592#POST1329592 Nalin thanks for your help I went and got the adapter and it worked fine. and I thank you for that I do need ur help once again plez after I had upgraded my 2500a set I began to downloade chanles and viewed them. I then once again began to download more chanels and the box went dead. the power will not come back on. is there anything I can do or should I call this one dead issue? if u can give me some guidence I would appreciate it very much. Rah I can also be contacted @ Rashala083@hotmail.com plez let me know something thanks again.
Username: Nydas
Post Number: 5361
rah: when you say "dead", do you mean that no lights come on anywhere? That could mean a blown internal fuse blown or wrong BIN causing total deep sleep needing jtag.
Username: Ricosaoco
Post Number: 34
HI THRE, I NEED HELP ALL MY PPV ARE MISSING i CAN SEE THE REST BUT NO LOS PPV ANY IDEA Y?
Username: Nydas
Post Number: 5362
Read some other threads here. There is a ECM since yesterday afternoon
Username: Ricosaoco
Post Number: 35
THANKS FOR ANSWERING i'M NEW IN THIS. CAN YOU TELL ME WHAT IS ECM i THINK IT MAY BE A PROBLEM THAT'S Y I'M HAVING PROBLEM..
Username: Nydas
Post Number: 5363
willy:
R E A D
R E A D
R E A D
R E A D
R E A D
