121 Int'l channels are down!
Username: Cailo
Post Number: 28
Now, this is happening more frequent. 110 and 119 are working fine, but 120, including Int'l channels are not working?
What is the deal now? Is there a new code to resolve this issue? Nothing happening at TOTALFTA.
Thanks
Username: Tapeman
New York City in-HD, NY
Post Number: 1874
121 partially moved to 118
Get a $40 Universal Circular LNB and a slightly larger dish to get all 3 again
Username: Vittu
Post Number: 48
King Tapeman: Can we use Dish SuperDish 121 Antenna with Universal Circular LNB?
Username: Tapeman
Post Number: 1875
yes
2 LNBs for 3 Sats (110/118/119)
1- Standard Circular for 110
1- Universal Circular for 118/119
Username: Dure
Mississauga, Ontario Canada
Post Number: 140
118,119 International channels are working?
Username: Brucelee
Beverly Hills, California United States
Post Number: 96
How about 61.5 Echostar 3? That seems to be down also.
Username: Nydas
Post Number: 5313
There is also a ECM going on. wait till this is sorted out before asking further help.
Username: Cailo
Post Number: 29
So
I am pointing at 121, with SuperDish. Autoroll is on, but didn't say channel not found, so I am not sure if channels are moved? If so, to what Dish so I can scan it again. Is there a new code for these channels?
Please if you respond, explain further instead of appreviations may be only known well by you
Username: Ke5aqn
Post Number: 1026
New Key's is NOT the issue here today people...if you are getting all channels except PPV, PURN, ethnic, and Most Movie channels then you have the newest key's.......
ALL RECEIVERS VIEWSAT,PANSAT, ALL CLONES are in need of new bins....as soon as the new bin's are out we will post the links
Username: Nydas
Post Number: 5359
Sadi Demaro: 121 channels are moving or moved to 118.7 Anik.
Username: Cailo
Post Number: 32
Where to find 118.7? I know there is 110 and 119, but I am unaware of 118.7? It looks too close to 119, so I will give a try and scan it, since iam pointing to 119
Thanks
Username: Ke5aqn
Post Number: 1029
Sadi,
what LNB do you have? it takes a liner not circular like for 119
Username: Cailo
Post Number: 33
I have the double LNB ( to get 110, 119)..I don't know exactly if it is linear or circular.
Many thanks
Username: Falcon21
Van, Bc Ca
Post Number: 16
there are no 118.7 on the sat list of VS ultra.
any idea how to add it? 118.7 and 119 is so close I don't know how will the LNB tell the difference..
Username: Ke5aqn
Post Number: 1034
is your antenna a dish 500?
In my plat i have to add it in the channel scan menu not sure if the same on yours Falcon...you also have to add the active transponders use lygnsat to look it up...
Username: Falcon21
Van, Bc Ca
Post Number: 17
Cool thanks, but I think we still need the new bin to receive the pictures right?
Username: Ke5aqn
Post Number: 1035
ya right now you could get the sat but, no pic on ethnic channels MUST have a liner lnb like for example for true FTA a lnb that gets 119 will not get that sat
Username: Taku420
Post Number: 24
Hi
I have superdish-121 (121,119,110).
Now the Int'l channels are moving or moved to 118.7 Anik; what changed do I need to do to my superdish 121. Do I need to buy a new LNBF? Do I need to set the angles again?
If I need to buy a new LNBF, can you please provide the link or a picture or a model?
Thanks,
T
Username: Ke5aqn
Post Number: 1037
I would recommend the best set up is, 31" dish, QTH-031 lnb, and motor. Cost is around $150. Set up is easy as pie. That way you would receive all sat's not just 3. Their are 35 sat's you could be getting.....
Username: Nydas
Post Number: 5366
I have been told but can't confirm fully that a minimum 30" Dish is must for the ANIK/Echo7 combo.
http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=COLtq4W ng5ACFQltZQod8TDDtA
http://www.usedottawa.com/classified-ad/4408471&category=tvs
Username: Taku420
Post Number: 25
Ok.. lets say I buy one of those LNBF which outputs for (118.7,118.8 and 119), All I need to do is to replace the new one with the existing 119 lnbf. RIGHT?? I dont need to buy another dish, Do I? Isn't the superdish 30" wide?
Plz advise.
Thanks,
T
Username: Ke5aqn
Post Number: 1041
I am not sure what LNB will fit easly on that dish mabee another user will know...
Username: Shopfree4pc
Here are some example pictures of how this can be done with superdish!!!
[link removed]
Username: Cailo
Post Number: 34
One thing will be highly appreciated. How to add 118 to VS, or other recievers?
