Viewsat ultra
Username: Prit
i am also having problems with my satellite..need help.. cannot watch anything since nov 21st, don't know how to fix or start fixing the problem..if someone can help will be grateful
thanks
Username: Kirankumar
Post Number: 96
Preet if you post in the daytime to Nalin he will help you set your box up.start your thread as"Nalin Help" and keep giving him all the info that he asks for.good luck
Username: Nydas
Post Number: 5261
Please post how many dishes, howmany LNBs and where are they pointing to. Name of receiver and when was it last working?. When you ask for system info, what do you see/
Username: Nydas
Post Number: 5262
Sorry, I just noticed "Viewsat Ultra in the title.
You need to install the latest ultra BIN file.
Http://www.totalfta.com
Download PFTAUSW-071124U-2.zip, unzip it and put the .pgm file into your USB drive. Then install it into your receiver using your remote.
