Sat 118 .....
Username: Realniceguy
Post Number: 20
what are the setting fo r sat 118 .. international channels ..... for example is it suppose to be univeral .... hel what are the dish setting
Username: Space_invader
Andromeda M31
Post Number: 222
To get 118W you need a LNBF that runs at 10750 freq... Right = Vertical , Left = Horizontal...
Here is a link to view the LNBF needed...
http://cgi.ebay.com/DUAL-LNB-CB2008A-ANIK-F3-FTA-FIT-SUPER-DISH-118-8-118-7_W0QQ itemZ150186461405QQihZ005QQcategoryZ149971QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This one is a little expensive... But is just to give an idea...
Username: Crazy_greek
Post Number: 1340
This is the LNB for the new 118°W (Anik F3 / 118.7° / 118.8°) satellite. With this special LNB, you can get BOTH 118 and 119 at the same time!
Works with both Free-to-Air and Original DN Receivers!
Requires: 30-inch or larger dish
Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and legacy switches (SW21, SW44, etc)
Not compatible with DishPro switches and/or DishPro (stacked) LNB's
SPECS
Polarization: Circular
Input Frequency: 11.70 - 12.75 GHz
LO Frequency: 10.750 GHz
Noise: 0.5 dB
Dual-output (ready for 1 or 2 receivers)
SETUP INSTRUCTIONS
Using a 30-inch or larger dish, aim with the following settings:
Satellite Name: 118°W (Anik F3) or 119°W (Echo7)
LNB Type: Standard (or Single)
LO Frequency: 10750 or 10600 MHz
Finally, do an AUTO SCAN or a BLIND SCAN
For some the following settings may work better or give you more channels:
LNB Type: Universal
LO Frequency: 9750 MHz
HI Frequency: 11750 MHz
