PLEASE HELP!!!!!
Username: Spider156
Post Number: 158
I have a Pansat 2500a original and I need to know what to do in order to get PPVs and HBO again!!! PLEASE HELP ME!!!
Username: Satgrl
Post Number: 673
HAHAHAHAHHAHAHAHHAHAHA......are u stupid or retarded....lol no offence but if pansat had a file support why would i have to buy a sonicview...u need to convert ur receiver to a 2700A ..then u can get the special files called jvvh..lol
Username: Spider156
Post Number: 159
fine i will but umm i didnt say anything about sonicview!
Username: Saqeeb9000
Post Number: 234
john throw ur pansat in a pan and fry it up...
and buy something new like sonicview,or Koolsat 6100 or viewsat ultra......................
Username: Satgrl
Post Number: 676
yahh um sure.....sada is ginving u the best advice do that ok..lol
Username: Spider156
Post Number: 160
tell me about this conversion?
Post Number: 240
satgrl u can handle this...
i have no idea about convrsion...
Username: Satgrl
Post Number: 681
here is the directions...Recently posted by the great Nalin..lol...
A. THESE INSTRUCTIONS APPLY TO:
Pasnsat 2500A and named and nameless clones of 2500A
Forect LifetimeUltra
If using an original pansat 2500a, install 293T or 294T Bin first
Any of above whether converted or not converted.
B. Sites for download of files.
[link removed]
[link removed]
http://www.totalfta.com
http://www.dssrookie.com
C. Preparation:.
Make a directory or subdirectory called 'jvvh'
Download files into this directory:
BL Updater 1.4, 225,280 bytes,
jvvh_208.1.bin, 458,752 bytes
jvvh_213.bin (optional)
Extract CS_224T_Lightning_100t_Series_serial.bin'" 448K bytes
from the zipped file CS_224T_Lightning_100t_Series_serial.zip
Note that you do not need the full jtag file.
(You may use the jvvh_Leafs+224.bin extracted from Jvvh_leafs(BG)_224.zip)
All these files should be in the jvvh directory,
Straight RS232 DB9 F/F cable.
Connect computer to receiver via serial port using 9 pin F/F DB9 cable above.
Receiver should be switched off.
D. Action:
If going from any jvvh Bin 221 onwardss, skip the installation of 208_1.
If having problems with too many resets or other problems, do the 208_1 part. </b>
Go into Windows explorer and find the jvvh directory.
Double click on BL Updater 1.4
Select BIN and select file jvvh_208.1.bin (do not select BOOT)
Left hand ready on switch of receiver and right hand ready on Mouse pointing to 'Write BIN'
Switch on and IMMEDIATELY CLICK 'WRITE BIN'
Wait, Wait, It will start loading the BIN, and go to100%
The it will say, 'BURN' on your screen.
The receiver will then show b75 flashing.
WAIT. WAIT
When you see the screen of receiver settle down at '5' , it is still NOT FINISHED.
You will see ON come on the receiver.
Turn receiver off.
This part is optional.
Repeat above selecting and using BIN 213. This time click the mouse for write AFTER seeing 'b' come on'. This is optional but recommended.
Repeat above selecting and using CS_224T_lightnimg_110t_serial.bin. This time click the mouse for write AFTER seeing 'b' come on'
With receiver showing ON, turn off the receiver and exit from BL updater 1.4
Disconnect receiver from computer.
E. Installation:
With receiver switch in off position, connect the Sat antenna, and the cables to TV.
Turn on TV
Turn on receiver.
You will see b75 go across and freeze on '5'.
WAIT
After a little while the TV will come on asking you to confirm Language
English.
Press OK.
First do Menu/System Reset.
It will ask for PIN '" use 1668 if you have forgotten your PIN, usually a 0000.
Next do default settings
Next do User setup. Set time to manual and enter the correct time, date, and time zone.
Make sure summer time is off.
Next do Menu/Dish Setup/Antenna setup
Select your known dishes and use the known DisEqC port connections.
You can connect to ports without knowing which is which using trial and error and the signal strength.
Now do Blind scan (power scan) for each of the selected sats.
You must see Vertical TPs.
F. Watching TV:
By the time you finish the blind scan, the new keys will have loaded and you are ready to watch TV.
You MUST switch off at the back once and switch on.
You can se up the channels alphabetically or in other ways using Channel Edit and Sort.
You can and should set up P-lock on some P0RNO channels.
You can rename the 5 Favorites using right arrow key.
If a channel does not appear, you can do a separate TP scan.
Also look for it in the list, e.g. channels 614 '" SET may appear in the list as TV 614, and you can rename.
HAPPY VIEWING
If resets occur, try turning autoroll off and auto TP off.
Post Number: 246
its complicated.........
just look my idea on top .....its simple....
