A question
Username: Newtofta
Post Number: 173
is there any way that i can save my channels so that i dont have to rescan sats when i load a new bin?
Username: Satgrl
Post Number: 646
yeahh dont do a facotry defualt just load bin like that
Username: Newtofta
Post Number: 174
when i loaded the last bin i didnt do a factory reset and i had to rescan
Username: Satgrl
Post Number: 651
oh did u load facotry bin?
Username: Newtofta
Post Number: 175
last bin i loaded was lightning 222
Username: Viruscauser
Leesburg, Georgia
Post Number: 452
New To FTA, get Channel Master for free from ShaprC and use it to read and save your channel list onto your computer. After loading the new bin, just write your channels back onto your receiver.
Username: Newtofta
Post Number: 176
so once i do that the channels will be there? No rescanning? thanx
Leesburg, Georgia
Post Number: 454
No rescanning. Heaven.
Username: Newtofta
Post Number: 177
thanx.....i hate having to rescan and deleting the channels i dont watch.
Username: Newtofta
Post Number: 179
i cannot get CM to read.....say process complete with errors...error communicate....and i know the cable is good.....have used it to load bins
Leesburg, Georgia
Post Number: 455
Are you reading it as a Pansat 2700 channel list as you're supposed to?
Username: Newtofta
Post Number: 180
yes
Leesburg, Georgia
Post Number: 456
That's strange. I've never had that problem. The only thing I can think of is: reboot everything, comp and receiver, and try again.
If that does not work, I hope someone with a better answer jumps in here.
Username: Newtofta
Post Number: 181
i rebooted everything and it worked....could have been cpu...... thanx for all your help abby
Leesburg, Georgia
Post Number: 457
Thanks for the feedback. Enjoy.
