Nobody knows about pansat 9200?
Username: Alex434
Hollywood, Florida USA
I need help, there is anybody who got the pansat 9200 with 8SPK board?? I cant scan the HD channels could you help?
Username: Dimwitt
Post Number: 213
install board
do factory default- all
antenna setup
scan
Username: Alex434
Tooter, thanks for the clue, but i did what you said and still not get the HD channels, on the DNW guide i see the programing and i know what channels are but they are not on my scanned list really strange, do you have one 9200?? i still need your help
Username: Dimwitt
Post Number: 214
i did as posted and got the channels on 110.
you could try tp scan, TP 12399 & 12457 with symbol rate 21500
future-fta.info has a 'how to scan hd channels".
Username: Alex434
I just tried it, and got nothing, makes sense my LNBs doens't work ?? like i said before i had a pansat 2700a it was perfect, so lnbs are not defective i just mention cuz a friend said maybe i need those new ones different ones, i don't know, i'll try the future site you gave me, now they are updating the site, it's not available tks
Username: Dimwitt
Post Number: 215
The lnb's you have will work for the hd channels also --no need to replace.
advanced & tp scan
when you have echo 8, tp 12457 and sybol rate 21500 selected the tuner type should read:
DVB-S2 / 8PSK / ON
Username: Alex434
yes, i did exactly before, the problem is when i choose 12399 or 12457 tps i have no signal evn quality, that's why i can't scan, i went to the antenna LNB to try better specific position, but get no signal and no quality for these tps, getting crazy here.
Username: Dimwitt
Post Number: 217
i lose signal and quality when the FEC for those tp's is not set at 2/3(advance & tp scan).
i would start over.
board installed,
cable in place-IF output to the illumanati board,
factory setting --all data
antenna setup,
scan.
thats all i got ...good luck
Username: Alex434
I'll change the antenna, got no success, but thanks for the help, by the way just Echo8 has HD nothing on echo7?
Username: Dimwitt
Post Number: 221
nothing on e7
more hd at
http://ekb.dbstalk.com/61-5list.htm
http://ekb.dbstalk.com/129list.htm
Username: Alex434
Post Number: 7
One more question for you, so if you have 110 and 119 you see DNW programing on PPV movies, with 9200 won't be able to watch those HD channels ?? there are about 7. Do you know anything about?
Username: Dimwitt
Post Number: 227
does DNW = dish network?
scanned about 14 hd channels at 110w ,
all viewable--ppv movies, espn, tnt,hd theater....
Username: Alex434
Post Number: 8
yes DNW stands for it, so I tried yesterday to change antenna etc... no signal, do you think it maybe the board?? i don't think there is any other cause, specially like you said the LNBs will work for it , but the guy who sold me said it was tested.
Username: Dimwitt
Post Number: 229
Advance and tp scan
select echo 8
down freq. 12297
tuner type should read--DVB-S/QPSK/OFF
Now select down freq. 12311
tuner type should change to -- DVB-S2/8PSK/ON
i think that indicates the board is recognized.
Username: Alex434
Post Number: 9
yes, the board is recognized, i have seen it , so still a mystery, why i can't see these channels you have, I'm waiting till future-fta site come back, but you gave me pretty much all to do, really upset here.
Username: Dimwitt
Post Number: 230
when tp 12311 is highlighted in advanve & tp scan, do you have signal and quality.
if not, maybe replace the cable from the IF OUTPUT to the board.
Username: Alex434
Post Number: 10
I did it, and have no signal, so i replace for another cable, and no signal yet.
Username: Dimwitt
Post Number: 231
can only suggest to start over,
Installing this kit is a simple procedure that does not take more than 5 minutes:
* Remove the top cover of your Pansat 9200HD receiver with a Phillips screwdriver.
* Remove the "Tuner 2 IF Out" cap from the back panel of the receiver.
* Make sure you are not carrying any static electricity by touching the chassis of your receiver for 2 seconds.
* Remove the tuner board from its anti-static bag.
* Install the adapter board to the tuner board and connect all supplied cables to that board.
* Tighten the tuner kit to the back panel of the receiver through the "Tuner 2 IF Out" opening.
* Connect the power cable to the power supply (CN3 connector).
* Connect the data cables to the main circuit board of the 9200HD (CH6 and CH7 connectors).
* Make sure the tuner kit is in place and not "slanted".
* Connect the RF cable to the tuner board and to the "Tuner 1 IF Out" port on the back of the receiver.
* Install the cover on the receiver and tighten all screws.
* Turn on receiver. The DVB-S2 / 8PSK option in the Advanced Satellite Scan menu will allow you to scan DVB-S2 / 8PSK transponders containing free-to-air programming.
i also did the factory setting --all data--
after installing board
good luck
Username: Alex434
Post Number: 11
thanks for all men, but i still with the same problem, after doing all again and again...
