Using a 4 way switch
Username: Scabz
Knoxville, Tn Us
Post Number: 34
Will using a 4 way switch with two recievers decrease any signal or quality value ? I have never used one before. Or is it best to run a seperate cable from the satellite dish to the recievers ? Thanks
Username: Tapeman
New York City in-HD, NY
Post Number: 1804
Yo can't use one DISEqC switch for 2 different receivers
Best way for 2 receivers is to use LNB with 2 outlets called dual LNB
Username: Scabz
Knoxville, Tn Us
Post Number: 35
Ok glad I asked before the headache. My LNB has 2 places to hook cable into. This is what you are talking about right ? Thanks alot
Username: Tapeman
Post Number: 1808
Quad
Yo can connect up to 4 receivers no problem
Username: The_messenger
Post Number: 54
scabz .....to answer your question NO
A multiswitch will not decrease the signal.
EXCEPTION
If a multiswitch is used only on FTA satellites and over 100 foot runs to a receiver there will be a DB lose....signal lose.
Dual LNB
Only 2 receivers
No need for any type of switch.
Username: Tapeman
Post Number: 1810
Every insertion has a dB loss 0.5db to up to 3.0dB
Every bad connection, shield etc. has an effect
Every multiple output has a signal to noise ratio
Yo'll notice problems for weak signals and perhaps loss of signals during rainy cloudy weather and/or plus if signal is not at its stronger level
So is quad ok or not to use
Yes, ok assuming all basic connections are right to accommodate dB loss to keep
it at a minimum level.
Username: Nydas
Post Number: 4996
I suppose one can always amplify the signals if there is an unacceptable signal loss....?
Username: Bruce69
Post Number: 28
HI NALIN;I INSTALED THE NEW BIN ON MY CONVERTED PANSAT 2500A.I FORGOT HOWEVER TO WRIGHT DOWN THE FREQ,LNB,DISEQ VALUES.I CAN NOT GET ALJAZEERA CHANAL CAN YOU HELP
Username: Nydas
Post Number: 5001
Go to Menu/User settings and change date, time, time zone and if necessary, the TV type.
Go to Menu/antenna setup and connect up the switches to the appropriate sats.
The do Blind scan or power scan.
Username: Tapeman
Post Number: 1814
- Amplify signal won't increase Q signal off the LNB to receiver
- Inline Amplifier replaces signal loss due to capacitance of cable and length of wire, shield etc.
- Any type of amplifier increases over all level along with signal to noise ratio i.e. noise increase level as well
s/n should be low (0.1 is best)
s/n over 0.7 is very bad
s/n =1 means signal= 100 % noise
Yo want to be around 0.5 or less
Username: Nydas
Post Number: 5012
Thanks.
