Platinum file bad
Username: Mclinkus
Post Number: 25
the file posted at total for paltinumns is the same file posted for extreemes use with extreeme catuion.
we @ [link removed] are on top of this situation and have removed the file untill we get verification
this file may not be good for your platinum
Username: Viewbass
so what the next step? where we can get the bin?
Username: Scabz
Knoxville, Tn Us
Post Number: 62
A bit to late for that now. My platinum is still alive even though I installed it.
Username: Coolgoose
Post Number: 53
here is the correct bin for platinum.
http://d3.b8.344a.static.theplanet.com/DBPSW-071124P.zip
They (totalfta.com) haven't correctly linked the bin for platinum . Even if your platinum is working with the bin for extreme i suggest you download this bin
Username: Tvhammer
Post Number: 17
GetDss.com
Username: Mclinkus
Post Number: 29
we do have the viewsat file that was not released on the main page of total
pay close attention to the file name.
071124x vs 071124p
the x is for extreeme the p is for platinum
they were not relsead like this on totals main release page
check out [link removed] for the correct files
this will not kill your box. ( i dont think)
just get the new file
Username: Bill038
Post Number: 183
john the spammer,,,you suck
