Any help would be greatly appreciated
Username: Lovadnun
Post Number: 12
Okay, so I have a fortec star lifetime ultra. I've decided a month ago that I would no longer pay someone to program my box. I've read over the threads and I'm able to complete the basics (inputing new keys...). I'm currently trying to figure out the downloading of new bins but I'm stuck and trying to figure out which bin to use. When I go to the main menu -> then systems it states ->JWH5897
X-87BL
API: 75-2.11_EUbX
Boot ver: 75
10.Sep.2007
I'm not sure if my box is cloned, converted....help. Which bin should I use, because at the moment I have to manually input keys couple times a day. Thanks in advance
Username: Saqeeb9000
Post Number: 168
use the below link to use loader...
[link removed]
below is the link to download files
[link removed]
Username: Lovadnun
Post Number: 13
Thanks
Username: Lovadnun
Post Number: 14
registration has been disabled :-(
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 192
there are tons of sites where u can get the loader/files/instructions you will need..here are some
www.totalfta.com
hope it helps.
Username: Lovadnun
Post Number: 15
What bin do I use? I'm not certain.
Username: Shadow45
Post Number: 194
If you have a converted FLU to 2700 then , you have to use either the ones made by CS or jvvh or the ones made by leafs.
the latest bin is the Cs_222T and jvvh_leafs_222 , both work the same way and again, read the other threads so you are better informed.
Post Number: 171
Deri use the bins what are for ur reciever.. look at files for ur reciever...all the sites have names for reciever....
look at lk's post he has list of good reputable websitess....
www.totalfta.com
Username: Viruscauser
Leesburg, Georgia
Post Number: 427
Deri A, you need to load any one of the two bins that SHADOW45 mentions above.
Username: Lovadnun
Post Number: 16
Thanks for the help everyone....wish me luck
