...Is This Right??
Username: Nlempb
Post Number: 43
pansat 2700a
echo 7 & 8
dn
wondering if my bin and boot files are up to date i have no ppv!
bin...X-87BL_070411_B75_203API
BOOT...2700A(B75)-(07)0310
THX 4 the help
Username: Rtap
FL
Post Number: 1079
nlempb the most current bin file is
(TBL version 223) Globe Cast Temporary Fix
WARNING: Use all files at your own risk.
File Type: zip X-87BL_071118_B75_223_api.zip
available at future-ftadorinfo or ftabinsdotnet.
this is how it works,
87 = for the 2700 series
bl = blacklist
070411= 07(year)04(month)11(day)
b75 = is the boot file
so just by looking your file is from 04/11/07,just the load the current bin and wait for keys to roll by itself,remember to turn on autoroll.good luck
Username: Nydas
Post Number: 4997
nlempb: A word of caution. There is a lot of activity in this and other forums about Pansat 2500 to Pansat 2700 conversions and conversions BINs. These BINs are modified from the original Pansat 2700 BINs but will NOT work on your Pansat 2700.
In any forum, go to the Pansat 2700 files section for files. Whilst there also pick up the 27.02 loader. You are going to need it. And get the instructions. Either of these files are OK, if you do not scan globecast.
X-87BL_071118_B75_223_api.zip (410.4 KB)
X-87BL_071116_B75_222_api.zip (410.3 KB)
[link removed]
[link removed]
Registration is free. Unzip files before use. Keep autoroll off after all installation is complete, so as to prevent resets.
