Which cable?
Username: Nlempb
Post Number: 40
i would like to know WHERE and WHAT KIND of cable i need to hook my pansat 2700 to my computer to download bins. any and all info is appreciated thanks
Username: Lklives
Post Number: 13690
this one...$10 null modem
http://www.globalwholesalers.biz/prod31.htm
Username: Nlempb
Post Number: 41
ok thanks.....one more where can i find the easiest and best instructions for loading bins....dont wanna screw it up the first time lol thanks again
Username: Nydas
Post Number: 4979
You need a DB9 F/F null modem cable (not straight RS232). It is usually available at your local computer store, Radio Shack, future shop, etc.
Username: Nlempb
Post Number: 42
ok thanks but this is where it gets confusing...one says this, the other says that..i value any and all info...but how do i know who or which to go with....once again thanks
Username: Nydas
Post Number: 4984
There is no conflict of information.
A null modem can come in many physical coinfigurations.
In the old days, 25 pin F/F, 25 pin M/M, 25 pin M/F
Later, 25 pin to 9 pin F/F, 25 pin to 9 pin M/M, 25 pin to 9 pin M/F
You need a DB 9 F/F 6 ft null modem cable.
Currently DB 9 (9pin) M/M, F/F and M/F.
In these you can get two inch solid adaptors or full cables 6ft and 10 ft long.
Username: Lklives
Post Number: 13695
Just buythe cable online from the link I provided...u will have it in 2 days...free shipping..
For pansat 2700 info, files, guides, manuals, go to their official Dss site www.future-fta.info
Username: Bouttep
Post Number: 47
what cable do i need for a pansat 2500a converted to 2700
Username: Rtap
FL
Post Number: 1058
follow this list joe.you use the same cable for the 2500 you have always used.straight db9 rs232
A
Ariza Ultra 400 - Null
Ariza Ultra 500 - Null
Ariza 700 - Null
Ariza 750 - Null
Ariza Extreme - Null
Astrovox 2600 - Straight DB9
B
Blackbird and ALL Blackbird CLONES - Null
BlueJay2 - Null
Buzz S2010F - Null
Buzz S2010F Plus - Null
Buzz S2020F - Null
C
Captain 7000 Premium - Null
Captian 8000HD - Null
Captain 9000DVR - Null
CaptiveWorks 100R PVR Unit - Null & USB
CaptiveWorks 500S - Null
CaptiveWorks 600S - Null
CaptiveWorks 600 Premium - Null
CaptiveWorks 1000 - Null & USB & ETHERNET
CaptiveWorks 3000HD - USB & ETHERNET
Conaxsat CNX-V1 - Null & USB
Conaxsat Duo - Null & USB
Conaxsat Trio - Null & USB
Coo*lsat 4000 Plus - Null
Coo*lsat 4000 Pro - Straight DB9
Coo*lsat 5000 - Straight DB9
Coo*lsat 6000 - Straight DB9
Coo*lsat 7000 PVR - Straight DB9 & USB
Coo*lsat 8000HD - Null
Coo*lsat 8100HD - Null
Cooltec - Straight DB9
Coship (All) - Null
D
DGStation Mutant 200S - Null
DGStation Relook 400S - Null
DGStation Relook 300SV - Null
Digiwave 5900C - Null
Digiwave 6800 - Null
Digiwave 7000 - Null
Digiwave 7200S - Null
Digiwave Diamond - Straight DB9
Dreambox (All) - Null
E
Eagle Star 2500A - Straight DB9
Ebox Mimic (Viewsat Clone) - Null
Extremeview Magnum XV3300 - Null
F
Fortec 5000v2 - Null
Fortec 5100 Diamond - Straight DB9
Fortec 5100 Plus - Straight DB9
Fortec 5100 Plus+ - Straight DB9
Fortec 5100 Ultra - Straight DB9
Fortec 5400 NA - Null
Fortec 5400 - Null
Fortec 5600 Plus - Straight DB9
Fortec 5600 Ultra - Straight DB9
Fortec 5600v2 - Null
Fortec ALPHA - Null
Fortec BETA - Null
Fortec LIFETIME - Straight DB9
Fortec Lifetime Classic NA - Null
Fortec Lifetime Classic - Null
Fortec Lifetime Diamond - Straight DB9
Fortec Lifetime ULTRA - Straight DB9
Fortec Lifetime Ultra Diamond - Straight DB9
Fortec MAGIC - Straight DB9
Fortec MERCURY II - Null
Fortec Platinum NA - Null
Fortec PLATINUM - Null
Fortec Ultimate - Straight DB9
L
Lava 2600 - Null
Lava 3200 - Straight DB9
Lava 3500 - Null
M
Max 2500 - Null
Megasat (All) - Straight DB9
Microroyal (All) - Null
Mvidea FS 4000 - Null
N
Neosat Lite - Straight DB9
Neosat Lite Premier - Straight DB9
Neosat iPro1000 - Null & ETHERNET
Neosat iPro2000 - Null
Neusat SP6000 - Null & USB
Neusat SP6000 Premium - Null & USB
Neusat 9000HD - Null & USB
NFusion Nova - Null & ETHERNET
O
Orasat V3 - Null
Orasat V5 - Null
P
Pansat 200A - Null
Pansat 250SM - Null
Pansat 300A - Null
Pansat 330A - Null
Pansat 500 CI - Null
Pansat 700H - Null
Pansat 1500a - Straight DB9
Pansat 2000V - Null
Pansat 2300a - Straight DB9
Pansat 2500a and ALL 2500 CLONES - Straight DB9
Pansat 2700A/E and MOST 2700 CLONES - Null
Pansat 3500S - Null
Pansat 3500SD - Null & SD CARD
Pansat 5000HC - Null & USB
Pansat 6000HXC PVR - Null & USB
Pansat 9000HD - Null & USB
Pantec/Multistar Max (All) - Null
Pantec/Multistar MS (All except MS1000) - Straight DB9
Pantec MX/Ultra - Straight DB9
R
Rex1 - Null
S
SatCruiser - Null
SatPros DSR500 - Null
Silver Bullet/ST 1000 - Null
Silver Bullet/ST 2000 - Null
Skytech 2700A - Null
Skyview 500 - Straight DB9
Skyview RX600 - Null
SkyView Plus SV-P1000 - Null
Smartwave 2500A-N2 - Straight DB9
Smartwave 2700A-N2 - Straight DB9
Sonicview SV-1000 - Null
SonicView SV1000 PVR - Null & USB
Sonicview SV-4000 - Null & USB
SonicView SV-8000HD - Null & USB
Sonicsat Koolsat - Null
Spacestar DVB500 - Null
Stealth 2000a - Null
T
Technosat 1010 Plus - Null
Techsat - Null
Traxis DBS 1500 - Straight DB9
Traxis DBS 2500 - Straight DB9
Traxis DBS 3500 - Straight DB9
Traxis DBS 4500 - Straight DB9
Traxis DBS 4550 - Straight DB9
Trimax T100 - Straight DB9
U
Ultrastar 5000 - Null
V
Viewsat VS2000 Lite - Null
Viewsat VS2000 Platinum - Null
Viewsat VS2000 Extreme - Null
Viewsat VS2000 Ultra - Null & USB
Viewsat VSPro - Null & USB
Visionsat IV200 - Straight DB9
Visionsat IV300 - Straight DB9
Vortex 2700 - Null
Vortex 3500 - Null
Vortex 7700 - Straight DB9
X
Xrica X-5 - Null
Username: Dr_dss
Post Number: 360
$10.00 for a cable "wholesale" yeah right.
go here
http://www.cablesforless.com
