Help with Sonicview 1000
Username: Newbie777
I can't get any channels from 118(anik f3) on this sonicview 1000 when pansat works fine when I use universal 2 set up (9750-10750). Sonicview do not have universal 2 so the selection only from 9750-10600. When I do a blindscan, it is locking on the tp but failing to get any channel. Signal and quality is in the 90s. Pansat picked it up without any problems.
If I am forced to use a channel list to load my channels for the 118, should I use the channel master? or is there another one i should use with the sonicview 1000?
Pleeeeeeeeeeeeeease help.
Username: Doreenakadj
Post Number: 731
go to http://www.dsscommunity*com/forums2007updatednewurl/viewforum.php?f=113 >> change the "*" to "." without the quotes (") I don't use Sonicview 1000 but maybe there is something in that link that can help you .. you will have to reg. to get in but its free
Username: Newbie777
thanks Doreen. I'll try.
Username: Newbie777
I was able to get the channels on Anik F3 but channel names are missing instead it is showing as Echostar01, Echostar02, Echostar03 etc...what am doing wrong? Pleeeeease help. Thank You.
