Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 366 Registered: Mar-07 | The bin has been released here: As usual, try at YOUR own risk and then report back here to help me decide if it's safe for me to try it out. ;) |
Gold Member Username: AsharfiPost Number: 1391 Registered: Aug-06 | kk ...last and the final time ... i re-downloaded the bin and followed the time ... working good |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 367 Registered: Mar-07 | AV, I need some clarification: WHICH CS bin have you tried? The one for the 2700 OR the jvvh type CS bin for the CONVERTED 2500>2700 boxes? |
Silver Member Username: Cricket674Post Number: 122 Registered: Feb-07 | I have a converted Pansat 2700a. I have these settings X-87BL API: 75.2.18_Eubx Boot version: 75 23.oct.2007 Is it safe for me to download the bin? If yes then which do I download ( there are 2 versions of bins) which one should I download?? 1 more question can I download the bin into my receiver using the Rs-232 cable??? |
Gold Member Username: AsharfiPost Number: 1393 Registered: Aug-06 | Chancysand released a new bin some minutes ago for the converted Pansat 2500 and the converted FLU, which are know Pansat 2700. |
Gold Member Username: AsharfiPost Number: 1394 Registered: Aug-06 | In other words, I have tried that JVVH TYPE bin 221 ... working good |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 368 Registered: Mar-07 | Thanks AV. |
Silver Member Username: Jigga19Post Number: 110 Registered: Feb-07 | Av where you got JVVH type bin... can you please post the link.. |
Silver Member Username: Jigga19Post Number: 111 Registered: Feb-07 | AV this is the one i have CS_221T_Lightning_100t_Series_serial.bin.... where did you get the JVVH can you please post the link for it. Thankyou... P.S is your signal level high or low.. |
Silver Member Username: Cricket674Post Number: 123 Registered: Feb-07 | Is it safe or no and 1 more thing do I have to do the "notes" shown on |
Silver Member Username: Cricket674Post Number: 124 Registered: Feb-07 | any body there to help me |
Bronze Member Username: StarmovilChihuahua Mexico Post Number: 74 Registered: Jan-06 | what it means "converted flu"? |
Bronze Member Username: Dj_asyaMontreal, Qubec Canada Post Number: 33 Registered: May-06 | IS THE BIN IS GOOD AND EVERYTHING WORKING FINE FOR PANSAT 2700 CONVERTED |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 370 Registered: Mar-07 | Bobby Joe, I've not tried it but the talk at FTABINS is that this file is good for the converted 2500>2700 boxes. As with all modified bins, try at your own risk. |
Silver Member Username: LroyPost Number: 304 Registered: Aug-06 | YES, GOOD FOR ALL CONVERTET 2500 - 2700 BOX.. |
Bronze Member Username: Koku99Post Number: 33 Registered: Jun-06 | This program has a lot of bugs in it. I've put in all the right settings and I could not get quality on the signals at first. Then I got singal on few of the tp's on 121. Can't get any singal on 110 or 119. I would recommend that you keep the 220 bin and wait for them to fix all the bugs on 221. |
Bronze Member Username: DannienjuliePost Number: 42 Registered: Jul-07 | what is the process of puttiny the new bin in plz |
Bronze Member Username: Koku99Post Number: 34 Registered: Jun-06 | If you have converted your 2500 to 2700 then the process is simple. You need a loader such as blacklist updater. Run the loader and chose the current file for your receiver which the 221 bin. Then write the bin. Instructions are in CS_221 file they have on various websites. However I would not load the 221 bin yet. It has a lot of bugs in it. |
Gold Member Username: NydasPost Number: 4751 Registered: Jun-06 | [link removed] [link removed] CS_221T serial bin FLU & 2500 to 2700 THIS IS FOR PEOPLE THAT BEEN CONVERT TO 2700 Thanks go to Chancysand for CS_221T_Lightning_100t_Series_serial |
Bronze Member Username: Dj_asyaMontreal, Qubec Canada Post Number: 34 Registered: May-06 | why am i getting the same channells every time i scan the stalite |
New member Username: ZerochronoPost Number: 6 Registered: Jun-06 | yeah i cannot get any channels like aljazzera and others on echo 3 ( 61.5°W) does anyone know which one i should choose for this bin |
Gold Member Username: NydasPost Number: 4759 Registered: Jun-06 | Many questions have arisen out of the use of latest Chancy and jvvh conversion BINs version 221. Please read this thread. You will probably find the answer. https://www.ecoustics.com/electronics/forum/home-video/402679.html |
