I have some problem with my COLSAT 5000 receiver. I couldn't get couple of chennels like PPV, all international channels. I tried to reinstall factory bin than install latest file again but I got the same result. Please guid me what should I do now......
Thanks
**-- **-- **-- **-- **-- **-- **-- **-- **-- **-- My reply: PPVs are on 110W. are you scanning 110W ? You should rescan, using Blind Scan, if available.
Internationals are on 61.5W or on 148Wor on 121W. It is usually a separate Dish for 61.5W and 148W. Were you getting them before? You have to go into antenna settings and make sure you are software connected separately through a different port number to the different sats and these settings match the settings physically on the switch on the roof. You can tell by switch ports in the software to see where you are connected.
Thanks for your reply nalin. It was working fine untill last month. I was getting all PPV and Indian chennals. I checked all the settings and I blind scan everything twice. But still doesn't work. Now latest thing is Now I am not getting any chennals. Before I was getting few english chennals.. Now nothing....
