Bronze Member Username: Fortec16
Post Number: 90 Registered: May-06
Posted on nimiq2 > 82W is not working? any sug.? need help |
Bronze Member Username: Gastrognome
Post Number: 81 Registered: Dec-06
Posted on delete channels and rescan |
Post Number: 91 Registered: May-06
Posted on done that still same. what the setting u have? help me out pls. I am going to delete one by one and network scan again. |
Post Number: 92 Registered: May-06
Posted on problem solved and closed the post. How did I solved? Delete all the channels and renetworkscan good luck |
New member Username: Ajiwa
Post Number: 4 Registered: Sep-05
Posted on I don't get it. What do you mean by renetwork scan. I rescanned and it didn't work. |
Bronze Member Username: Ds_edm
Post Number: 96 Registered: May-06
Posted on why don't you try bliendscan |
