Zinwell Multi-Switch Question?????
Username: Cybermaster
Post Number: 75
Yellow,
I wanna get a multi-switch as I'm not satisfied with gayy 4x1 ones. I'm gnna get 4 fta receivers. I've got dp34 but requires a dish receiver to be connected with at all times. At any moment I disconnect the receiver, then everything goes black.
Anyways, I came across Zinwell WB68 multi-switch. I doesn't seem to require power injector. One of the things that I've heard about the switch is, it can only be connected to 2 fta lnbs. The rest of ports must be connected to dtv lnbs.
If anyone has used or is using one of the zinwell switches, please let me know. I would greatly appreciate it. Thanks.
Username: Cartier1
Post Number: 1328
cyber since u voted for me i will help :-)
dp34 dont need any power injector.
you use the power injector with dpp44 and that in thne case of using dpp lnb's.
the best switch for 4 receiver getting 3 satelitte is dp34. is smooth . excellent and reliable. but you got to use all lnb's dp.
and not dpp.
dp=dishpro dpp=dishpro plus
any question let me know.
