Can i use starchoice antenna for DN or bev? thanks
Username: Bashir77ca
Post Number: 9
can i use starchoice antenna for DN or bev? thanksUpload
Username: Dr_dss
Post Number: 180
Yeah sure can you need to change out the lnb and will need to mess with the focal point a little but other then that it a breeze.
And you will notice a little less rain fade.
Username: Kjniceguy
Lethbridge, Alberta Canada
Post Number: 111
You will Also have to decide whether to point dish at Bell or Dishnet since they are in complete different points in the sky
Username: Dr_dss
Post Number: 182
That was a given was it not
for DN or bev?
Post Number: 10
thanks alot guys that mean I cant use starchoice lnb.
Username: Dr_dss
Post Number: 183
Correct that means that
Username: Kjniceguy
Post Number: 112
YOU will need to buy a FTA LNB to replace your Starchoice LNB. Once you do that, you then need to adjust your Position of the Dish to the Appropriate Satelite that you want ..ie dishnet 110 119 or Bev 91 . once you do that you will be up and running. Also note that if you are wanting More than 1 sat you will need a 2nd LNB and a disque switch as well as More Cable. Just a friendly note... Each sat you want requires additional LNB's and posibly additional Dish's
Username: Dr_dss
Post Number: 203
You right there Kevn
only thing is FTA lnb?
You think about it both circular and Linear are what you would call a FTA lnb seeing they both could be used to watch true FTA channels on the various sat's beaming down radition into the brains of mankind.
But for the most part.
Starchoice -Linear
DN's - Circular
