Pansat 2700a- Bev user
Username: Yousuf786
Hi all and LK
how are you all.
I have not used my receiver, but will need to since NHL is starting soon, lol
I have loader 27.02 (B75) and i loaded both BIN 211 and 213
it downloaded 100% but now the receiver is just flashing....
normally it will flash and then go "ON"
can someone please help me to fix this?
Username: Millhouse0601
I have a question about my pansat 2700a. I have combined the 110/119 signal and it shows on the pansat that I have good signal for the echo 7 and 8.6. The only problem is locking my transponder. I cannot lock the transponder for the echo 7 but it is locked on the echo 8.6. Is there a way to get all transponders locked on the one with the good quality and signal?
Username: Banti
Post Number: 208
carolos maybe u have the old bin that is why night rider flashing. so what u gotta do is load a better bin a newwer one and itill work.
and milan gagner u should check the switches in the insalation maybe the settings are wrong.
I am sure i have installed it correctly. I have two satellites, the one with the 110/119 signal has a dual twin lnb going into the disque switch while my other satellite for 61.5 goes into in the disque switch. On the pansat it shows that I have good signal one by one but it won't lock in on the transponder with the best signal. Any suggestions?
