LNB Types Needed By Satellite List
Username: Lklives
Post Number: 12088
c/p from drstrange
There are two types of Ku band LNBFs- circular lnb's which have a low frequency of 11250 mhz, and linear lnb's, which have three different frequency ranges, universal - 9750mhz-10600mhz (European model), universal - 9750mhz- 10750 MHz, ( U.S. model's use both and are wide band LNBFs), and standard - 10750mhz.
Here is a list of satellites and the correct lnb's to use with them:
61.5W Echo 3 - use standard circular lnb - 11250 MHz
63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz
71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz
77W Echo 4 - circular standard lnb - 11250 MHz
79W Amc 5 - linear lnb, either universal or standard - 10750 MHz
82W Nimiq 2 - circular standard lnb= 11250 MHz
87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz
91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz
91W Nimiq1&3- circular lnb standard= 11250 MHz
93W Intelsat 6- linear lnb, either universal or standard-10750 MHz
95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz
97W Intelsat5- linear lnb, either universal or standard - 10750 MHz
101W Amc 4 - linear lnb, either universal or standard- 10750 MHz
103W Amc 1- linear lnb, either universal or standard- 10750 MHz
105W Amc 15- linear lnb, either universal or standard- 10750 MHz
107.3W Anik - linear lnb, either universal or standard- 10750 MHz
110W Echo 8 & 10,X - circular lnb standard - 11250 MHz
111W Anik f2 - linear lnb, either universal or standard - 10750 MHz
116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz
119W Echo 7 - circular lnb standard - 11250 MHz
121W Echo 9 - linear lnb, either universal or standard - 10750 MHz
123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz
127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz
129W Echo 5 - circular lnb standard - 11250 MHz
148W Echo1 & 2 - circular lnb standard - 11250 MHz
