I lost all english channels
Username: Gonxggo
I deleted all the channels I had. After that I ran blind scan for echo 3, 61.5, echo 7 119 and echo 8 110.
I receive all the south asian channels but I don't receive channels like CNN, CNBC TBS etc.
Also, when I select switch "off" I don't see any signal strength for english channels.
Please help.
Username: Gonxggo
I also don't get Zee Tv. Can someone please help? What is the TP for Zee?
Regards
Username: Nydas
Post Number: 3653
ZeeTV is TP 12603(V) on Echo 3.
You occasionally don't get all channels after a blind scan and have to do TP scan.
Username: Gonxggo
Nalin,
It didn't work either. It is only scanning two channels.
I was getting all channels this morning but some english channels were not showing good quality. I deleted all the channels and then ran blind scan and now I am screwed.
Do you think I messed something up?
Please help.
Username: Viruscauser
Leesburg, Georgia
Post Number: 156
gonxggo, blind scan Echo 3 (61.5) after setting the Diseqc switch to #3. Blind scan even if you don't see any signal strength when you set it to Diseqc #3.
Do that and report.
Username: Gonxggo
Thanks Abby,
I do get Zee and other South Asian channels now but still not english channels like TBS, Comedy Central etc.
If you know how to resolve it please reply.
Gonxggo
Leesburg, Georgia
Post Number: 193
I'm guessing blind here because you don't provide a lot of relevant information but here goes:
The English channels are on Echo 7 and Echo 8. If you have a dish pointed to those sats, and the cable goes through the same switch, Blind scan Echo 7 on Diseqc #1 and Echo 8 on Diseqc #2.
Username: Banti
Post Number: 156
do a facotry set do a sat scan and make suere ur switch configuration is correct, like Abby said Diseqc switch to #3.try that then hit the receiveer off from the back the turn it on after a minute and wala ur done
