VHS to DVD how? please help!!!
Username: Heather85
right, for fathers day my dad said you can get a cable(?) to connect the VHS player to the PC to copy VHS to DVD any ideas im so confused!
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 70
yer u get a rca cable runnin from the vhs to the video input of the video card of the computer im a smartazz 11 year old
Username: Dandandan
Post Number: 132
yer yer
Username: Catchum
I want to copy a dvd to vhs without using a computer. I think I need a stabilizer but do I come out of the dvd player go into a stabilizer out of stabilizer go into the vhs player/recorder? Can it even be done this way?
Username: Subwoofaz_rock
Post Number: 19
look all u do is buy a dvd recorder then u conect ur vcr rca cables to the input of the dvd recorder press play on ur vcr then press record on ur recorder then you will get vcr to dvd
note: wen u do this you will not see a pic on the screen unless u get rca cables and conect it to the output of the dvd recorder then conect to the tv im a smartazz 11 year old
Post Number: 20
yer yer
Username: Catchum
Are you sure? I want to put a DVD disc on a VHS tape, so I should'nt need a DVD recorder just a DVD player. I will for sure need a VHS recorder.
Post Number: 28
oh ur talkin bout the other way just get the rca cables yellow red and white from the dvd player and hook that into the input of a normal vcr then play the dvd and press record on the cvr player im a smartazz 11 year old 12 soon!
Post Number: 29
yer yer
Username: Yrios477
i need help recording from vcr to vcr. please help
Username: Darrenjae
Hiya..Im trying to collect abbott & costello films on dvd,though there are a few of their films which are only on vhs,ive already transfered a couple to dvd with no problems,for some reason my dvd recorder has started to pick up the copy protection code and automatically pauses record,i dont understand this as the films i have already done and the one that wont record are all from MGM/UA home video.
Is there any way around this?? Iam using a BUSH DVHS1VCR/DVD combi to play the original VHS recording and a YAMADA DVR-800 DVD recorderfor the burning.
Please help
Username: Cfriesen
paste this link into your browser
http://reviews.cnet.com/4520-11259_7-5705957-1.html?tag=bnav
Username: 001daner
Russ, Becky & Darren,
Search eBay for "Sima CT-2". Expensive but effective.
Need to Register?
Forgot Password?
Enable HTML code in message
