Help!! lol
Username: Sennis
ok, i just bought a Captive works cw-600s premium
it was working for a week and now i get scrambled channel coming up all the time
i have no clue at all how to reenter keys
im using *bell expressvu*
ive noticed where keys are that theres a 86: and 96: but when i go into my keys, under the nagra2 the only thing i get there is 80: and 90:
and when i go to edit i get
000000-00-(then the big code here)
i dont know what i need to put into the first 8 0's
at the moment there saying
00 0901 80: key
Username: Sennis
got it done now :-)
Username: Yumyum
Post Number: 13
If you find yourself the 1.45 bin it will roll those keys for yah!
Username: Lklives
Post Number: 11194
here the 145 autoroll fix...just remove the * in the link...and yes U must register FREE here, like all other sites...
[link removed]
Username: Brucester
Post Number: 524
and if you want to put keys by hand hit the page down on remote then hit red button on bottom of remote this will let you put in active keys this is the fastest way to put in the keys hope this answer your first question but the 145 bin is rolling good
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 257
if ur lost just go to the newb thread plenty of help there
lol
